Results 1 to 5 of 5
    Feb 2021
    Tewksbury Ma
    Default Brake linkage rod #3 for 2015 F3s
    I use the #2 brake linkage and would like a little bit more stretch out for my legs.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    I have the opposite issue because I'm only 5'3" tall with very short legs. Hope someone can explain the different effects of the different length in rear brake rods. Hope mkuszek gets an answer, and someone might help me get a pedal that's higher up from the floor boards. My Spyder is a 2014 RTL.
    Aug 2016
    Maine
    I just replaced my pos 3 with pos 5. whats your zip? I'll check shipping costs. My bike is a 2018 F3, should be the same
    Active Member robtdonna's Avatar
    Jul 2014
    Ellijay, Georgia, United States
    REDRAZOR: If you have a RT(L) or any RT you cannot change brake rods. That is only available in the F3 series of Spyders.
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Feb 2021
    Tewksbury Ma
    I got one coming from a member so I no longer need it. Thank all.
    Please delete post
