Results 1 to 6 of 6
    Sep 2019
    Cold Lake Alberta
    Default Coolant question - would you use Honda Type 2 in your Spyder?
    My wife has a 2015 RT special series. I’m thinking of changing the coolant. I have on hand Honda Type 2 coolant (I have lots). Would you use it in the spyder?
    Opinions please.
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    If you are doing a complete change, and have a user’s manual for the bike, check the specs to see if the Honda meets the specs. Also if you can see what color coolant is currently in the bike by looking at the overflow tank, and the Honda coolant is the same color, and is for motorcycle use you should be fine.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Sep 2019
    Cold Lake Alberta
    This is what the Honda says
    “Recommended antifreeze
    Pro Honda HP Coolant or an equivalent high quality ethylene glycol antifreeze containing silicate-free corrosion inhibitors”
    Idaho
    Quote Originally Posted by splake0 View Post
    Opinions please.
    From what I find it is an ethylene glycol antifreeze mixture formulated specifically for aluminum engines, the same as is required by BRP. You do not dilute it with water but use it straight from the bottle. After you drain the RT refill it with water a time or two and flush out all the original coolant before you put the Honda mix in. It's best to not mix brands.
    2014 Copper RTS
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    The short answer - YES!
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Very Active Member Pandy's Avatar
    Mar 2011
    Lake Wylie South Carolina
    I completely agree. Honda coolant, formulated for aluminum engines will perform well and is widely available. And as stated, a through flush and clean. Planning on doing that my own self upon pending radiator replacement.
    David
    2011 RTS 2006 Yamaha Morphous
    2017 F150 2015 MINI Cooper S IBA 56167
