Results 1 to 13 of 13
    Nov 2012
    South Texas
    Default Battery tender hookup
    I have a 2017 RTL. Can I use a battery tender by connecting it to the outlet in the trunk. I realize I will need to switch the fuse from position number 6 to number 7.
    Thanks for any help.
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by ValleyRider View Post
    Worked for me on my 2015.
    Nov 2012
    South Texas
    Thanks
    Nov 2012
    South Texas
    Any idea where I may find this type of tender?
    Feb 2017
    My preference is the Battery Minder Plus and it can be found at Amazon.
    Sep 2020
    Platte City, MO
    I'm partial to the Deltran Battery Tender brand.
    Jul 2014
    Mint Hill, NC
    I've used a Battery Tender Jr. since I bought my Spyder. Walmart has them online for about $31, Amazon for $25. The selling dealership comped one and installed the fused pigtail to the battery. I can use the pigtail to power my emergency compressor if necessary which I would not do with the trunk receptacle.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    I have five Deltran battery tenders. Need I say more?
    Idaho
    NAPA has one I use much of the time. You can find any number of units at big box stores, Amazon, and auto parts. Just make sure you buy one that clearly states "battery maintainer". If it says charger or trickle charger but does not say maintainer do not buy it!
    2014 Copper RTS
    Jul 2018
    Fountain Hills,AZ
    Same here! Never failed me
    Nov 2012
    South Texas
    As usual Spyder Ryders come through with first class information. Thanks to all.
    Feb 2021
    Gulf Breeze, FL
    Why wouldnt you use trunk recepticle for compressor??
    Idaho
    Quote Originally Posted by iwillplay View Post
    Fuse isn't sufficient. From the factory it's only 5 amp and a compressor is more like 10 amps. Or did you mean battery tender? If so, the trunk receptacle works just fine for a tender.
    2014 Copper RTS
Tags for this Thread
