Battery tender hookup
I have a 2017 RTL. Can I use a battery tender by connecting it to the outlet in the trunk. I realize I will need to switch the fuse from position number 6 to number 7.
Thanks for any help.
Worked for me on my 2015.
Any idea where I may find this type of tender?
My preference is the Battery Minder Plus and it can be found at Amazon.
I'm partial to the Deltran Battery Tender brand.
Peggy and Howard
Hers: 2013 Spyder ST-S SM5
I've used a Battery Tender Jr. since I bought my Spyder. Walmart has them online for about $31, Amazon for $25. The selling dealership comped one and installed the fused pigtail to the battery. I can use the pigtail to power my emergency compressor if necessary which I would not do with the trunk receptacle.
NAPA has one I use much of the time. You can find any number of units at big box stores, Amazon, and auto parts. Just make sure you buy one that clearly states "battery maintainer". If it says charger or trickle charger but does not say maintainer do not buy it!
Originally Posted by ARtraveler
I have five Deltran battery tenders. Need I say more?
Same here! Never failed me
As usual Spyder Ryders come through with first class information. Thanks to all.
Why wouldnt you use trunk recepticle for compressor??
Fuse isn't sufficient. From the factory it's only 5 amp and a compressor is more like 10 amps. Or did you mean battery tender? If so, the trunk receptacle works just fine for a tender.
Tags for this Thread
