Results 1 to 16 of 16
    Nov 2016
    Franklin North Carolina
    Default Is there a trick to checking the tire pressure in the rear tire?
    I have a 2020 rt limited and I looked for and found the tire valve for the rear tire. It is on the sproket (belt pulley) side and sticking straight out and not up. There is less than maybe a 1/2" clearance if that. How the hell do you check the pressure and add air if need be?
    Dec 2020
    Down South
    I have an extended valve connected to halo air pump that I use to check tire pressure and add air. So, it makes it easier. So, with that said, either find an extension to add to the tire's stem, or use a something to check the tire pressure that has a long valve. Makes it a lot more manageable than trying to be a contortionist
    Feb 2012
    Spring City,Utah
    Harley has the same problem with their Ultra rear wheel so the sell an extension that is about 6-8 inches long and really helps check and fill that rear valve. Some have also fitted a second valve stem bu drilling the right sized hole at a more convenient place.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Nov 2016
    maybe I am missing something. My valve stem stick straight out towards the flywheel. If I add an extension when the tire spins it will hit the flywheel at some point.
    Nov 2016
    Okay after looking again I see what you are talking about. Thank you for the advice. Next stop auto zone lol
    Sep 2018
    Florida / NC
    Understand, it is a pain for an old man!
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    That's one reason I put FOBO2s on the bike. Only have to mess with the valve if/when the tire gets low.
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
    Aug 2020
    California
    I use a screw on hose and a smart compressor that stops at the set pressure. Air loss on removal is not an issue.
    Dec 2020
    Hartwell, Ga
    I check and add air to mine just as it came from the factory, no problem for me
    May 2020
    Bunnell Florida
    i lay on the floor..remove the valve stem cap...take a reading...add or minus air..recap done..
    Sebring, FL
    At 88, laying on the floor being a contortionist is a problem. Do I do it, sure, but it ain't no fun. Could BRP have simplified this, I think so. But look, BRP didn't build these things just for me, so I adapt as required.
    Durham,Maine
    At 88 find some young buck to check it for you!! I hope I am riding at your age
    2012 RTL , Pearl
    Sep 2014
    USA
    I use a long reach digital air gauge. Yeah you still have to get down there but makes it easier when you have a extended wand on the aur gauge.
    Sebring, FL
    Thanks Mickey, I also have a bicycle I try to get in 10 to15 miles on most days, yes sir, I am blessed with two wheels and good health. So not complaining about the rear tire. :>)
    Feb 2012
    Spring City,Utah
    Bill as always you are my hero. Whenever I am tempted to let age hold me back,I think of you. Keep on keeping on pal.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Doc McCoy View Post
    I remove it after checking the pressure. I buy them at the Harley Store,$10.95. I keepit with my tire gauge.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
