Results 1 to 12 of 12
    Feb 2021
    Gulf Breeze, FL
    Default Spyder Reverse tow on Trailer hitch - anyone tried?
    Anyone have any experience with these?
    https://www.motorcycle-rack.com/CanAm_Tow_System.html
    Feb 2019
    Portland, Oregon
    Pray that it doesn't rain.
    Dec 2013
    There's a couple of earlier threads on this; some with posts in them where the poster ignored all the warnings against trying it and said they'd give it a go, promising to report back & tell everyone how wrong they were..... But I haven't seen any of them come back again to tell us their Spyder survived & the device was actually any good; just like I've not yet seen anything suggesting that really they AREN'T one of the worst ideas anyone's ever come up with for towing a Spyder yet?!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Looks low what about road kill?
    Nanny would have a coronary if she knew what was going on
    2017 F3S Daytona , Circuit Yellow Metalic
    Aug 2019
    southwest oHIo
    I see three concerns, one of which might not be much of a problem.
    1. Towing backward with windshield attached. Behind a motorhome, there might be enough of a wind break, but if you try that behind a pickup, van or car, that windshield will catch a LOT of air.
    2. Nose clearance. The nose is already rather low, low enough to scrape when entering a driveway. How much clearance will be left when the rear is lifted several inches into the hitch cradle?
    3. Steering lock. The front wheels will have to be locked somehow to prevent them turning side-to-side. The only mechanism on a Spyder holds it at full lock, not straight ahead.
    There are probably more, but that's what I see on initial inspection.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Not for me or my Spyders. Anyone who can afford a big rig like shown, can surely afford a real trailer.
    A $400 item can do much damage to both the Spyder or the tow vehicle. Not worth the risk, IMO.
    Feb 2021
    Gulf Breeze, FL
    Default interesting trailer
    Feb 2021
    Gulf Breeze, FL
    Thanks for the insights. I am still leaning toward a full trailer behind my 31 foot rv but had to check it out. My only hold up is the length. The rig is already long enough and adding another 10 foot is going to be painful.
    The price of fun escalates.
    Feb 2021
    SC
    Many years ago I used something similar to tow a Honda 350 motorcycle. When I got to my destination, the bracket that went into the receiver was bent down. I would not use anything like that again. On the other hand, for something like the Spyder or Ryker, you could make a piece that goes on a hitch ball and is "L" shaped with two small wheels that the rear tire of the Spyder or Ryker fits in.
    Jul 2014
    Mint Hill, NC
    No way!
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Nov 2016
    Upstate NY
    The other problem I see is the bolt that holds the platform to the 2x2 hitch. I assume the platform pivots there to allow the spyder to go around turns. How long is that bolt going to last? I am not going to trust a 1100 lbs spyder to one bolt. Im sure the hole will wear quickly also or possibly wear into the bolt compromising its strength. The strap should be included for that price also. Seems like some backyard inventor to me.
    2021 Sea to Sky RT , Highland green
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    That looks a little scary....
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
