Results 1 to 6 of 6
    Mar 2015
    forrest above Reno, Nv
    Question One armed ryder needs comms - any suggestions?
    My friend has the use of his left arm only ( Right is there but not working). HE CAN RYDE JUST FINE. We are looking for a communication system/method as he often leads and I ryde sweep. He has a foot throttle( pretty neat) and his left hand is pretty busy with steering and shifting. I thought a phone ( which he always carries) mounted on the bars with bluetooth earbuds would work BUT still involves removing his steering, shifting hand from the bars. He understandably is uncomfortable with that.
    I believe that he doesn't want a Sena like system for him and his wife.
    Any suggestions are most welcome,
    Lew L
    Last edited by Peter Aawen; 04-26-2022 at 11:30 AM. Reason: Removed Prefix - this is a 'What should I use?' question not a 'How To: DIY' guide. ;-)
    2014 RTS , Circuit Yellow
    The Sena like System is the system that will actually work best.
    Once turned on and paired to the other send/receive unit(s), the channel can be left open. All that is needed to activate is for someone to start talking. Instant, hands free, communicatoion between units.
    I have tried all of the main systems out there in the last 12 years or so. Now on our third set of senas. Currently Bell Magnum/w built in Sena units. just my .02.
    Feb 2022
    New Zealand
    How about a Voice Activated Mike setup like you get in Helos and stuff?
    Thinking further, or a foot operated push to talk switch, for the other foot thats not on the throttle.
    Northern Kalifornia
    I still have my first Sena and is 100% reliable 100% of the time.
    Oct 2015
    Lynden, WA
    Good work Lew. Perhaps with the newer Sena units the group could all connect thru a mesh.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2015
    Us too. Too reliable and simple to replace. Trying to get communication from road cap to the sweep.
    Lew L
