Will wheels from a 2018 Spyder fit a 2009?
Will wheels from a 2018 spyder fit a 2009?
Reason: Removed extra CR ;-)
They will, but the fronts are 15" as compared to your 14". If you were planning to swap tires the fronts will not fit. Rear is the same size.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Wasn't there some discussion in the past about how using a larger diameter tire on the front might affect speedo readings and Nanny's control of the bike?
2014 Copper RTS
Not if you keep the ratio close. Look for total tire diameter when comparing tires. Since the speedo reads from the rear wheel it's not as sensitive to the front tires. I have had no issues going from the stock 50 to the 65 I am running on my 2020 RT(205/65R15) on my rear.
There are speed sensors on all three wheels that feed into the Vehicle Control Module. We don't know what the interaction is among the three when it comes to supplying a speedo signal to the cluster and what the tolerance is for variations among them. But we do know that the VCM compares all three constantly because that is what kills cruise control when a tire starts sliding. The VCM communicates with the cluster, including speedo reading, via the CanBus.
2014 Copper RTS
Reason: 'Done' ;-)
