Results 1 to 11 of 11
Thread: Spring updates
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default Spring updates
    Have spent the better part of eight hours disassembling and reassembling my 2018 F3-T. Took the kendas off and replaced with Vredesteins all around. While apart I looked @ the brakes, about half gone, so placed an order with Ron for new brakes, and caliper reducer.
    While waiting for the order, which was here in a day and a half thank you for your outstanding service as always Ron. I went to Lowes and got some of the threaded clips to attach to the tabs on the belt guard covers. It was tough enough to remove the two 10mm nuts, I wasn't going to fight with trying to put them back on. This modification made reattaching the belt guards so much easier.
    Used silicone spray lube on the rubber drive line shock absorbers under the sprocket on the rear wheel. pumped up the brake pedal before turning on the key, went for a nice ride, seated the new brakes and scrubbed the mould release compound off the new tires.
    I found I have a belt tensioner on this. I have a question for the forum, what size roller is used on the BRP tensioner?? Mine is less than 2 inches in diameter. Have the BRP tensioners been upgraded since they were first introduced?? I recall a lot of problems with failures and destruction of the drive belt when they were first introduced. Having purchased this used from I-Motor I was not able to discuss this with the original owner.
    I noticed that the catalytic converter impedes the swing arm from dropping much after removal of the lower shock bolt. I was able to work the drive belt off by side ward pressure and rotation of the rear tire. This allows you to remove the rear tire and not have to redo the belt tension, tracking or alignment. Saves the laser alignment if you have had this done previously also.
    Now @ 7700 miles I am ready to travel and not have any concerns for neglected maintenance. Oil change @ 9000 miles and will be good to go.
    Al in Kazoo
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Oct 2020
    Arizona
    That blue text hurts my eyes! RU the same guy that does all blue text on RV.net?
    Dec 2020
    Hartwell, Ga
    I agree about the blue text, but to answer your question if you have the original brp tensioner you need to buy the roller/bearing kit from Lamonster, the roller is bigger and has better bearings.
    RE: Blue text. I like it and the extra size of the font is easier on my eyesight.
    Sep 2015
    Chilliwack, BC. Canada
    X2. I find it much easier on my eyes.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Feb 2019
    Portland, Oregon
    The blue is OK, but does it have to be bold too?
    Sep 2020
    Platte City, MO
    That blue is awful. Give me a normal black on white background.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by K80Shooter View Post
    Thank you for your answer, from the difference in roller size I most likely have the BRP tensioner. Will put an order into spyder pops for the new roller as he's $11.00 cheaper than Lamount for Lamount's own roller replacement. And as so many complained about my blue print, will leave this black, but bold and larger is easier on my 70+ year old eyes.
    Al in Kazoo
    2018 F3-T
    Sep 2020
    Platte City, MO
    Thank you, now I don't have squint.
    Peggy and Howard
    Aug 2018
    Chicago
    Quote Originally Posted by IGETAROUND View Post
    Al in Kazoo
    keep it blue DONT GIVE IN I luv BLUE
    Dec 2013
    Quote Originally Posted by Snoking1127 View Post
    Quote Originally Posted by Possible View Post
    Quote Originally Posted by Brad0414 View Post
    It's off topic a little I know, but it is important!
    The thing about using Blue, Red, or Green for large blocks of text (as opposed to just highlighting the odd word or two. ) is that there's a significant portion of the World's population who are 'colour blind' to some degree, and as quoted here:
    Most colour blind people are able to see things as clearly as other people but they are unable to fully 'see' red, green or blue light.
    so if you do use those colours, you are very likely making it MORE DIFFICULT for some (many??) to clearly see your posts, let alone read them! . Sure, bolding the text &/or colour might make it 'stand out' a little more in your eyes, but if your reader happens to be colour blind (even just a little!) in that particular colour (or more!) then bolding big blocks of it doesn't really help much - in fact, if it's big blocks of text & therefore colour that you're bolding (rather than individual words, which increases the contrast!) then it could even make it worse/harder again for them to read/decipher!! And Colour blindness to some degree &/or a reduced ability to see/read clearly is far more prevalent than you might think, especially amongst the 'more mature' readers out there.
    All of which means that if want to use an alternative colour to the Forum default, then using any one of those three (3) colours will be the WORST choice of colours you could make!! . That'll be made even worse if whoever your reader is doesn't have a 'white background' on their screen, so 'Changing your default text colour' to any of those 3 is NOT a really great idea, not if you want everyone to be able to read your posts!
    If it helps you to see, or even if you just must change your text colours, then you should instead try changing the text size &/or 'bolding' it, as I've done above & in the following: Larger sized text that is Bolded in the Forum default colours will make your posts easier to read for FAR MORE of your potential readers than changing the text's colour to any variation of Blue, Red, or Green! Thank you for thinking of ALL your potential readers!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
