2017 Spyder F3 Parking Brake will not release?!
My parking brake will not release. I have disconnected the battery and reconnected but no luck. At least it's in the garage and not on the ride I took today.......can anyone address this mishap?
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
The only way, I know of, to release the parking brake is to take the brake cable or the actuator lever off the fixturing point near the axle.
Look for a video on YouTube. I carry 2 12mm combo wrenches just for this issue.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
Put a rock behind and in front of the rear tire before you loosen that 12mm nut! EXPERIENCE TALKING! Loosen the nut, count how many times you spin it. Take it home ignore the dumb beeping. Once you get home put a rock in front and behind rear wheel, open the brake side panel, get an air hose blow out the wheel, wipe the lever with a thin soft rag and see if it engages. If so tighten nut same count and your good till next time. It will happen again.
Happen to my new 2019 f3s too, disconnected the cable reinstalled and never had a problem with it again
richie spyder
I absolutely love this forum and the ability it affords one to find solutions to problems. My 2018 F3-T had this issue when I picked it up with 15 miles on it. The mech disassembled the actuator and reassembled and it "worked". 1000 miles later, same issue. Gave a Brake Switch error thru the BUDS, but switch and wires checked out. Adjusted the PB cable, solved for now. Seems like too much torque for the motor to release.
pauly1 - SpyderDeb's 'wrench'
2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
IBA #48220 SS1000 BB1500
2015 F3-S , OEM na Basic Black with Custom Wrap
Pauly1, I think that is the key, the correct adjustment of slack on the parking brake cable IMO
Al in Kazoo
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
My 2015 had this problem at about 77,000 miles. It turned out to be a failure of the electronic module that controls the motor for the brake, and the motor that lowers/raises the windshield. Replaced under warranty, including the $50 tow bill. (But I had to pay the $20 cab ride home, 12 miles, then drive my car back the next day, to meet and direct the tow driver.) I knew nothing about pulling cables to release the brake, but the dealer tech did, to drive it of the tow truck. It was slid onto the steel truckbed rear-wheel first... no biggie.
I had to wait several days for the new module to ship to the dealer.
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
