Results 1 to 8 of 8
    Nov 2013
    Blue Springs, Mo.
    Default F4 customs windshield on Ryker
    Got my new F4 winshield today for my Ryker. Looks great EXCEPT very crooked leaning to one side. I suspicioned the info module was not straight across now I know for sure. Does anybody know how the module is mounted and can it be moved so that it is straight? No big deal with no windshield but now it really shows up. Just put it on this evening after mounting the BaJa Ron sway bar, finder lights (had to take the fenders apart for Lamonts plug and play), then Lamonts LED headlight bulbs, one in and one to go.
    Thanks for any help on straightening out the module.
    Dale
    Jun 2015
    Ritzville, Wa
    I had the same problem with my F4 windshield. There is a single screw, I think it's a #30 torque up under the instrument panel. I can post a few pics tomorrow of where you should look cause it's night time here now.
    It was kind of a pain in the butt to get to, but I managed to back it out and discovered it had some lock tight on it, but I guess it didn't hold too well. Maybe the windshield was putting too much stress on it or something.
    Anyway, once I got it out, I put some blue lock tight on it and screwed it back in. Then I straightened up the instrument panel/windshield and cinched the screw down tight. Have not had a problem with it since.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Aug 2019
    Battle Creek, Michigan
    gkamer a picture would be great.
    Jun 2015
    Ritzville, Wa
    For some reason it's not uploading the files. I'll mess around and try again.
    Greg Kamer
    Jun 2015
    Ritzville, Wa
    Looking from the front of the bike:
    Look just below the windshield mount:
    It's hard to see because it's behind the middle cable coming out of the instrument panel:
    You can push the cable a little to the side to see the screw.
    And before anyone's mentions it, I know there is a bolt missing on the right side. I was gong to remove the windshield to make it easier to see the bolt you need to tighten, and then realized it would not make a difference. But trust me, it's back there����
    Greg Kamer
    Nov 2013
    Blue Springs, Mo.
    Greg,
    Now that I got the crooked windshield out of the way I was looking at the front shocks and I dont see any notch for a spanner wrench to make an adjustment. Have you adjusted yours ? I thought about jacking up the bike to unload the springs to see If I could turn the adjustment. Still learning my way around this Rally.
    Dale
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by Spyderdale View Post
    Greg,
    I believe you can only adjust the front shocks on the Rally model. I have the 900 ACE model. But I did find this video:
    Hopefully this will help.....
    Greg Kamer
    Nov 2013
    Blue Springs, Mo.
    Thanks Greg. Kinda what I thought jack it up to take the load off and turn by hand.
