Results 1 to 8 of 8
    Active Member mully's Avatar
    Jul 2018
    Harrison, wisconsin
    Default DIY hand guards for my 2018 F3s
    20210302_135756 (2).jpg20210302_135710 (2).jpg20210302_135227 (2).jpg20210302_135041 (2).jpg20210302_135024 (2).jpg20210302_134610 (2).jpg20210112_103918 (2).jpg20210108_135403 (2).jpg20210108_134724 (2).jpg First made a cardboard mockup out of cardboard of hand guard then bought a 3' length of aluminum flat stock(1/8" x 2"). Cut to length and bend in jig, round off ends, drill holes and paint. Spacer was a 1" hockey puck drilled out with a hole saw. Hardware used was button head M6 x 20mm on the end of the handle bar and M4 x 60mm thru the spacer. Haven't tried them yet because there is still snow on the ground but they are only 2" wide so they don't block the mirrors sight, but should block rocks or other road debrie.
    2018 F3s, 2016 versys 650LT, 2001 concours 1000
    Active Member Woodswoman's Avatar
    Nov 2020
    Upstate NY
    Thank you! Excellent idea, photos, and details.
    2016 Spyder F3-S
    Oct 2015
    Lynden, WA
    Nice job. Looks great.
    Novel use for a Hockey puck as a spacer..
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Oct 2020
    Arizona
    Look to close to the handle bar grip for safe use, and not tall enough to really help with cold wind on ones hands.
    Nov 2020
    Upstate NY
    Quote Originally Posted by Snoking1127 View Post
    ... and not tall enough to really help with cold wind on ones hands.
    Probably would deflect a cicada, though! We're due for a big hatch this year in upstate New York. Man, those things hurt when you smack into 'em while you're riding!
    2016 Spyder F3-S
    Feb 2019
    Portland, Oregon
    I love to see these DIY workarounds. Money saved and the satisfaction of a job well done.
    Jul 2018
    Harrison, wisconsin
    20210304_080812.jpg Sometimes pictures can be deceiving so I measured it showing 1 3/8" opening. Don't know if that would be unsafe but my gloved hand fits with room to spare. I'll find out when I take it out this spring. I couldn't make them any taller because that would block the view of the mirrors but should shield your hands from taking a direct hit.
    Jul 2018
    Harrison, wisconsin
    Over the winter I made another set of hand guards making them wider (3") and alittle farther away from the hand grip.
    Doesn't hit the windshield and doesn't appear to block the mirror. Can't wait to try them when it warm's up.
    mully
    Resized_20220323_120421.jpg Resized_20220323_120329 (3).jpg Resized_20220323_120318 (2).jpg
