Results 1 to 8 of 8
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default 2020 RT Limited swirls in the paint
    So my new 2020 RT Limited looks like the dealership washed it with sandpaper. Swirls in the paint EVERYWHERE. I bought some Maguires Swirl X, but it didn't seem to do a thing. Has anyone found a way to fix this?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Quote Originally Posted by FINFAN3DP View Post
    This *sucks .... I'll bet whoever did the first or second wash didn't use enough water or didn't rinse it well while it was dirty .... the only thing I would try is a light polishing compound ..... and do a small inconspicuous area using almost no pressure .... wash and see if it worked .... if not try a little more pressure etc. ..... wishing you success .... Mike
    Sep 2020
    Platte City, MO
    What does the dealer say about it?
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Sep 2014
    USA
    I would agree with Mike. But not seeing what you have we are just guessing ..
    But try a light rubbing compound in a small area first as suggested.
    And also try the dealer first before you do anything as suggested.
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    I noticed on my 21 RTL that the Tupperware shows hairline scratches when the sun hits it just right. Really noticeable on the black top case. The finish needs a couple more layers of clear coat before it leaves the factory. Tried using Canuba wax, no luck. I will try some McGuires swirl remover and a couple of layers wax next.
    GLIDE-ON>>>>>>>>>>>>>>
    "Blue Belle" 2021 RTL Chrome in Petrol Blue
    2021 RTL Chrome , Petrol Blue
    Sep 2020
    Taxachussetts
    3M makes a clear coat wax, which is available at stores which sell automotive paint. Leaves the finish scratch and swirl free. But, your finish sounds like it needs a light buffing to eliminate most of the heavy stuff before wax.
    Joe
    Apr 2019
    Ohio
    Most of my glossy black trim has the swirl marks on them and I am also searching for a product which might help in removing them. I did come across a segment in the vlog “cruisemans garage” where he demonstrated how to remove light scratches from a Goldwings saddlebags. His demonstration would seem to be a bit much for a whole bike but may give you some ideas. I did not try his procedure so I have no first hade experience as it it’s effectiveness. I’m often concerned, when attempting repairs such as these, that I might make things worse.
    Poasttown, 2019 F3L
    Oct 2016
    Sebring, FL
    That's a bummer for sure. Once you drive it off the lot, might be a stretch to get the dealer to do anything. Hope you find something that works. If not, Wrap my Syder, a vender here, sells a variety of decals that might cover the worst.
