SSV Works Ryker radio
Taken from a trike with only 670 miles on it, this radio is virtually new, and is in perfect condition. The SSV Works RKR-2K blue tooth am/fm radio media player is made specifically for the Can-AM Ryker machines. It will fit the 600, 900 Ace, or Rally models. This offering includes everything you need, all the original parts -- control unit, "brain", antenna, and all wiring and hardware. There are also printed installation and operating instructions. Installation is plug 'n' play, and requires no modification of the original motorcycle wiring. It will not work with the Can-Am windshield because it uses the same mounting holes. This radio retails for $525 - $600 nationally, but you can have this one for only $300 plus $20 shipping. Or if you are in SW Oregon, you could pick it up and save the $20.
