Results 1 to 8 of 8
    May 2019
    Mt. Juliet, TN
    Default Helmet Lock Device on End of Which Grip
    Any preference as to which side of vehicle/handlebar to install "helmet lock" ? I have one on order (do not need two) and expect I am not considering something about placement you guys may have discovered: convenience, obstructions, etc.? 2020 F3-T
    Feb 2019
    Portland, Oregon
    The side you get on and off would work for me,
    Sep 2020
    Platte City, MO
    I don't use a helmet lock, but my thought would be to put it where it won't be in the way when mounting or dismounting. To me that would
    be on the right hand since I always climb on from the left. But JMO.
    On Edit, I just assumed you were referring to locks on the handlebars, but you may be referring to having locks elsewhere. If elsewhere I
    would think they would be better on the left side since I mount from the left.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Bossier LoUiSiAna
    Seem to use one on the Rh side more often. Maybe just because turn & lock bars to left like my two wheeler *note: have LidLox turned so helmet can sit on grip & not hang from straps.
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    On my RT I had the helmet locks on both sides, just incase needed to lock up passengers as well. As far as what side made no difference, your not riding when it's locked up.
    Jan 2021
    Descanso, CA
    I use a Helmet Hook on the left side handlebar with the open locking tab cut back to about 1/2 inch. I only use the HH for gear-on/gear-off purposes. I keep my helmet in the frunk because the face shield is photochromic (Bell ProTint $149) and leaving it in the sun shortens its life. Same with the helmet liner.
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    An alternate idea is to get a pistol lock (used to be free at police departments). I covered the braided wire with plastic tubing just to protect everything and you can then lock the helmet (by the "D" rings) to the passenger handgrips and place the helmet on the passenger seat.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    May 2019
    Port St. Lucie, Florida
    Quote Originally Posted by SpyderConvert View Post
    Geez! I never thought of using those for a helmet lock! Great idea!
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
