2015 Spyder F3s battery removal problem
Sure isn't much room to get the battery out of the frunk. It is loose but I still can't get the darned thing out of there. Saw videos of other models but not for the F3S. Is anyone out there a master at removing the battery? It is the stock battery Thanks
I have replaced many of them. Remove the rubber strap and the hold down bracket on top. Tip the battery forward and grab it by the top and lift out.
Thanks for the reply. How does the rubber strap come off? It is connected to the bottom of the battery and is in the way of tipping the battery forward.
Unhook the rubber strap from the upper bracket. It does not need to be removed from the bottom. Tip up the upper bracket and remove. Tip the top of the battery towards the front. Then lift.
2018 F3 LIMITED
The rubber strap unhooks from the bracket at the top.
