Results 1 to 25 of 47
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Default D.I.Y. oil change o ring kit
    Searched but couldn't find the sizes for all the o rings and crush washers to complete an oil change.I need to stock up from ebay does anyone have this information at hand? I know I should have saved the old ones but didn't see the need at the time.
    I have bought from BajaRon before but freight cost is silly now for such little items from US.Mostly postage free from China. Local suppliers buy from China and multiply by five or more so they're out Can Am blackmail you by requiring the purchase of their oil to get the full o- ring kit so I've divorced them
    Also why one copper and one aluminium crush washer, anyone know the science behind that.Can one be substituded for the other? Please help my head hurts.
    Feb 2012
    Spring City,Utah
    I don't have the information you are looking for per se,but I do know this,if you want the correct o rings and copper washers(they are not crush washers) then contact BajaRon a supporting vendor on this sight and he will fix you up with as many as you want all in a package. Check the Home page for his info.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Quote Originally Posted by Cobwebs View Post
    I re-use " O " rings all the time .... my 14 RT has had 10 oil changes and the " O " rings ( filter and plugs ) have been re-used for all of them ..... a rubber " O " ring that is not part of " moving " parts rarely needs replacing .... when / if they break replace ..... jmho ..... Mike
    Sep 2018
    Australia
    OK for you guys close by but out here in the sticks if I order a dozen sets its A$173 with $37 of that being postage.
    If I can work out the sizes I'll have a lifetime supply for way less than the postage alone.
    Sep 2018
    Australia
    What are the implications of one of the O rings splitting under pressure on the sump bolt or filter thingo though Mike.They seem like a fancy design for some reason to me. Could be the first indication of one letting go is a rattle For a few cents and an easy change why risk it?
    Sep 2014
    USA
    I went to mcmastercare and bought washers with the rubber seals on them per JCThorne recommendation. They are reusable .. its posted somewhere just need to do a search and find them now for sizes.
    Found it.
    https://www.spyderlovers.com/forums/...ealing+washers
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    Found it.
    They are also called Tredo washers, might help when searching for them
    Sep 2014
    USA
    Quote Originally Posted by Greven View Post
    I am sure they are called other things too like bonding washers.
    That should help too on searching. ��
    IMHO, you ( me ) are more likely to damage a rubber washer / O-ring, either removing it or putting it on ..... Mike
    RE: Shipping
    Please note the OP is from Australia. That is the reason for the complaints about high shipping costs.
    Shipping has gotten outrageous! The reason China can ship for 'Free' is that the government subsides it.
    I can ship 4 seal kits for $8.30 USD. 8 seal kits for $9.35 USD. And 12 seal kits for $10.40 USD.
    The seal kits are $6.95 each. 12 seal kits would be $83.40 USD. Making 12 seal kits (delivered to Australia) about $136.00 AUD total cost.
    Feb 2012
    Spring City,Utah
    AR thank you for pointing that out. I had not noticed that, it does make a big difference.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2018
    Australia
    Found it.
    Good information, thankyou.I wonder does the thickness matter. I've found some at 1.5mm and others 2.0mm, given that there are two o rings sealing something in the engine would half a millimetre screw that up somehow?
    It matters to a point. It depends on application. Low or no pressure O-Ring applications like the Spyder are pretty forgiving.
    It's not a primary and secondary seal. 1 O-Ring seals one end, and the other seals the other end with a flow port in-between. Both need to work as they have no secondary backup.
    Sep 2018
    Australia
    My first oil change did prove your point actually Mike. I think it was the green o ring had a small piece split on it that was still attached to the inner wall of the o ring..........just!
    Came from the factory like it, only visible when I removed it.Glad I did, who knows where it would have ended up if it came free. So for me the moral of the story was, its the bits you can't see that can cause the grief.
    Sep 2018
    Australia
    Free market isn't exactly the mantra of USA either but I digress.
    I must be missing something Ron, fleabay is quoting me $119.89 for the goods, $37.13 postage $15.71 GST.
    Total $172.73
    The heck with that come on spill the beans break out the vernier
    Total $172.73
    What you are missing are the eBay/Paypal fees, their shipping policies and the new (we're here to help) national tax being collected for most countries now. The most expensive place to purchase anything from me is eBay. The least expensive way to get it is by a direct sale.
    And you're right. America has been a socialist country in many ways for a long time. And we're headed for much more. I don't know why people can't see it. Saying that you're not socialist isn't the same as actually being non-socialist. We have gotten away with it for this long because our GDP is so tremendous. Sooner or later, our chickens will come home to roost. But I'm not supposed to talk about these realities... ;-)
    Jan 2021
    Descanso, CA
    What came out of my 1330 was a copper washer on the gearbox drain plug (TL) and an aluminum washer on engine drain plug (still on plug). My Gold Plug MP-18 came with an aluminum washer (TR). My Can-Am XPS oil change kit came with aluminum washers (ML and MR). I used captive seal washers instead (BL and BR).
    Sep 2018
    Australia
    Quote Originally Posted by BertRemington View Post
    What thickness captive seals did you use Bert ?
    Wasn't at hand, but I got it! This should help, I think! Ever tried measuring the diameter of a flexible ring? My numbers should be close, but they are a bit squishy! (pun intended!)
    The O-ring numbers are OD x Thickness. The washer numbers are OD x ID. All are mm.
    Jan 2021
    Descanso, CA
    CW -- I bought this assortment https://www.amazon.com/Hilitchi-180-...dp/B07CKVYWD4/
    The rubber insert is 2.5 - to 2.6mm thick and the metal rim is 2mm thick. I used a digital torque wrench with the same settings for metal washers although 15Nm would probably be adequate.
    Turns out that assortment was handy. I've been using the washers as spacers, etc.
    Sep 2018
    Australia
    Come on this is a family show Idaho
    Your the man that's perfect thanks !!!
    Sep 2018
    Australia
    Excellent thankyou. I'll start amassing my kit.
    Sep 2014
    USA
    The ones I used were 1.1 to 1.4 thickness from mcmaster carr
    Sep 2018
    Australia
    Is that the stock thickness also do you know? Perhaps IdahoMtnSpyder could wave his magic wand over one for us. Probably doesn't matter according to Ron but given a choice.
