Results 1 to 13 of 13
Thread: What is this?
    Nov 2020
    NE Florida
    Default What is this?
    While looking under my 2021 RTL to see if it came with the belt idler (which it does) I noticed this disconnected. Does anyone know what this is in the picture?
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by agrimm01 View Post
    Ride height adjuster lever....should be connected to lower control arm.
    Picture not super clear....is there a bolt in the nutsert on the lower control arm....if so....attach.
    It controls air bag for ride height.
    2019 F3L , Covid Blue
    Nov 2020
    NE Florida
    Quote Originally Posted by bikerchris1270 View Post
    Yea, the red oval needs to be thicker to see it well. That's what I thought it was but I didn't know the right name for it. There is no bolt in the nutsert on the lower control arm. I don't think it was ever attached.
    If you have a BASIC RT it may Not have auto ride control ( my basic 14 RT didn't ) ....without Auto Ride Control it has no function .....jmho .... Mike
    Nov 2020
    NE Florida
    It is an RT Limited. I will put a bolt in it. It's not worth the hassle to take it back to the dealer for this.
    Mar 2013
    M6x20 available a hardware store
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2020
    NE Florida
    Quote Originally Posted by PW2013STL View Post
    Thanks, I will get one.
    Sep 2014
    USA
    Was it left out or fell off??
    I heard of dealers not installing those bolts.
    Are you bottoming out??
    Durham,Maine
    It should handle and ride a hell of a lot better! Good luck!!!
    Last edited by Peter Aawen; 02-21-2021 at 02:44 PM. Reason: Changed 'right' to 'ride'. ;-)
    2012 RTL , Pearl
    Nov 2020
    NE Florida
    I'd guess it was left out. I only have 50 miles on it. Not sure if that is something that is installed at the dealer or at the factory. I haven't felt it bottom out but haven't been on rough roads.
    Nov 2020
    NE Florida
    It should handle and right a hell of a lot better! Good luck!!!
    Thanks, I thought it was handling good. Should be great now.
    Sep 2014
    USA
    Call the dealer and have them send you one for free. JMO
    Anyway good luck.
    Nov 2020
    NE Florida
    After putting a bolt in the linkage and starting it up I could hear the compressor release air every now and then. It will be interesting to see if it rides any different.
