Results 1 to 11 of 11
Hybrid View
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default 2020 RT Limited Power & SOUND through the USB, or only power?
    Can I get power and sound through the USB cable in the glove box? Or just power? Say I don't want to use the bluetooth. (cuz I know that is what everyone is going to ask)
    I just tried it, and it seems if I want sound too, i have to plug into the aux cable, which isn't a great idea as I have a newer phone with usb/headphone in one jack, so I have to use a splitter.
    FIN
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Dec 2020
    Down South
    To my knowledge, Short answer = no
    The USB port is primarily for data transfer and using the BRP app, but not audio. That's why they offer the aux port and Bluetooth options. You may be able to find some aftermarket hacks though.
    Sep 2014
    Parrish Florida
    Aux cable needed on mine for sound
    2020 RTL Chrome Marsala Red
    Jun 2018
    HAYMARKET,VA
    Bumble, have you used the bluetooth and not liked it? I'm worried about it interacting with our senas, which we do not use for music, but for conversation.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Ok, thanks. Would have been great had they incorporated the two!
    Baja Ron Sway Bar
    Key Cover from Ebay
    Sep 2014
    Parrish Florida
    We have 2 new Sena Cavalry blue tooth helmets. When the phones are paired to the helmets and the Ipod is Aux cabled on there is no interference. The BRP setup is borderline useless to us.
    Also, you have to make sure the Ipod is on and the bike powered to get the music playing.
    Aug 2018
    Huntsville AL
    I have a 2020 RTL, I plug my phone in and run Pandora all day. Also have used a MP3 player with pre recorded music.
    Jan 2021
    Orlando
    I have a 2020 RTL, I plug my phone in and run Pandora all day. Also have used a MP3 player with pre recorded music."
    I assume via the UBS connector
    May 2009
    poestenkill, ny
    What brand mp3 do you use. I have an older mp3 player it will not work. 2020 spyder rt ltd.
    Mar 2021
    Ohio
    Quote Originally Posted by louisbasle View Post
    Same question. I need some kind of a adapter to connect my 4th generation ipod nano with the old style 30 pin plug. I need a adapter to connect the other end to the little 1.5(?) connecter in the glove box. Any help is appreciated. Thanks.
    Mar 2021
    Ohio
    Quote Originally Posted by spyDerred15 View Post
    I've got 2020 Spyder RT Limited, my android phone is paired to Bluetooth. I can play music that way but my 4th generation ipod nano with 30 pin plug needs some kind of adapter to hook it up the little male plug in gloves. I can't find adapter anywhere. Any advice is appreciated. Thanks
