Results 1 to 3 of 3
    Oct 2015
    Lynden, WA
    Default Alignment of Fog/Driving Lights ??
    What are the dimensions for Alignment of Fog/Driving Lights ?? 2017 F3T.
    Specifically is there a correct distance and height for the aiming of the Aux lights.
    The manual states a target for aiming the high and low beam of the headlights but nothing for Aux lights.
    I have a pair of L4Xray lights. I'm building mounts that will (hopefully) have limited Horizontal and Vertical adjustability. Just need to know where to point them.
    Thanks, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Aug 2019
    Stoughton, WI
    Are they more of a spot beam or a flood beam? I basically go out on my street late night and park in my driving lane. I adjust the beam to reach out enough to see down the road, but not high enough to blind oncoming traffic. Much easier to do with a spot beam, almost impossible with a flood beam.
    2022 RT Sea To Sky
    Oct 2015
    Lynden, WA
    Troop, Thank You.
    I believe they will be more of a spot beam.
    I like your process. I'll be heading out to the street for final adjustments.
    David C
    2016 F3T
    Rear IPS Pack Rack
