Rear left storage compartment is stuck
Not sure how to get it open. Any suggestions? Before you ask, it is unlocked.
Fred is a 2010 RT SM5.
I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
Hi I,
Push ( medium hard) on the compartment door as you pull the lever to open it. Lubing everything will help but the cable can be adjusted. It isn't to hard to get to the cable adjusters.
2014 RTS in circuit yellow, farkeling addiction down to once every few months.ECU FLASH IS GREAT.
+1 on what Lew L said. Our left saddlebag on our '18 RTL needs to be pushed in as I pull the opening lever. It's not that much of a problem as it always comes open, but I probably should adjust the cable and lube it. Oh, well, I'll just call it an anti-theft feature.
2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
Motorcycle Rights: Charter Life Member AMA, MRF, FORR Local 11 Southwest Missouri, Mid-South MILE organizing committee member
2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
+ 2 on what Lew says.
I have the same problem with my 2014RTS-SE6.
Deanna
 2014RTS-SE6 Cognac
BRP Semi-Rigid Rear Side Cargo Travel Bags
BRP Glove Box Organizer
Ron-rnet Laser Alignment
TRIC-LED Spyderpockets
STV Black Carbon Fiber Windshield Blackout
WRAPMYSPYDER.COM Sceptor Kit Reflective Decals-Orange
After market Dashboard+ GPS plug-in
BRP Half Cover
WRAPMYSPYDER.COM Air Dam Web Decal Black Reflective
General Altimax RT 43 Rear tire
BRP Full cover
TRIC-LEDS Front Fender Marker Lights & Saddlebag Markers Lights
Read page 137 of your operator's guide.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Yep, +2 on Lew. My 14 stuck for a while when it was new and a gentle push with my knee popped it right open. A little lube seemed to cure the problem. A light whack with the heel of my hand makes sure both sides are latch 100%. You'll never forget that if you ever have one that pops open on the freeway. Thank goodness the dash lights up and goes crazy when that happens.
Be careful. I've read on Facebook post where more than one owner has snapped the lever off.
