Results 1 to 5 of 5
    Mar 2020
    Cape Coral, FL
    Default 2018 F3s Gear position sensor
    Anybody know where gear position sensor is located? Received the dreaded P2806 code with R and N flashing on the dash and E for gear. Trying to see if I can avoid taking to the dealership.
    Thanks
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by jjpgator View Post
    Thanks
    Below and just forward of output shaft( front drive belt pulley)...and forward of the control lever....left side as sitting on bike.
    Gearbox position Sensor:Hall Effects Sensor. 3wire connector, 5volt,signal, ground.
    2019 F3L , Covid Blue
    Mar 2020
    Cape Coral, FL
    Thanks!
    Mar 2020
    Cape Coral, FL
    Replaced the sensor and still having the same issue. Any ideas?
    Apr 2020
    Edgerton,WI
    Default Code description
