Results 1 to 16 of 16
    Feb 2021
    Georgetown, KY
    Question Can anyone tell me the difference between a 2020 and a 2021 Ryker Rally
    Good Morning Everyone!
    I am a new member, and potentially a new CanAm rider. While I am new to three-wheel riding, I am not new to two-wheel riding. I have been riding for about six years. I want to ride two-up, but for some reason, lack the skills, or the bike to do so effectively. So I am going to buy a Ryker Rally.
    I have two options: a 2021 brand new Ryker Rally for $11.5k or a used 2020 for 11k with 700 miles on it, which has some of the options I would have added to the brand new one. Can anyone give me the difference between the two model years?
    I don't want to pay the depreciation on the 2021 so I am leaning towards the used one. If anyone has any information that I can make a decision would be great!
    Thank you in advance.
    Frank
    May 2013
    Apex, N.C.
    Quote Originally Posted by LadyKira View Post
    Frank
    I am not sure about any differences, but I would not pay $11k for a used one. If you do decide to take a closer look at the used one, check to see how much warranty is left. The original warranty started the moment that it was put in service. That could make a difference.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    There are no differences between the two years. If the 2020 is coming with some of the options and it only has 700 miles on it then I would go for the 2020. Make sure its up to date with any recalls and such. I would also get the 3 year warranty on it as well, and I would get that through iMotorsports as it seems to be the best price.
    As a comparison, I have a 2019 Rally with passenger seat and backrest and I paid around 13k out the door.
    Feb 2021
    Georgetown, KY
    Thank you. I didn't think about asking about the warranty. I just assumed that it had expired. I will look into the extended warranty. I usually get them when I make a car purchase.
    I told the dealership about the recall and the salesman stated that they would take care of it.
    The warranty would make a difference, as I currently have a $1,400 price difference with the new and used bike. The cost of the new Ryker is 11,578, but with all of the accessories I wanted that the used one has would be $12,155. The used one out the door was $10,700.
    I am going this weekend to look at the used one and I will ask more questions.
    Thank you again for the responses!
    Feb 2020
    N. Wilkesboro, NC
    See if the dealer will throw in the BEST warranty. I bought a new holdover 2018 RTL about a year ago. Since the OEM warranty was just about to expire, the dealer threw in the BEST warranty. I traded it off before I needed it but it was nice to know it was there. Since some dealers (think iMotorsports) sells it for $671, I'm guessing dealer cost is somewhere around 1/2 of that.
    Aug 2019
    Battle Creek, Michigan
    I agree 11K is to much for a 2020. I just bought a 2020 Ryker Rally for $8500 with 700 miles on it. I see them for anywhere between 9500 and 10500 especially from individuals. Check Market Place on facebook. Good luck.
    Last edited by Peter Aawen; 02-16-2021 at 11:42 AM. Reason: Removed duplicated first sentence. ;-/
    Aug 2020
    Niagara Falls NY
    Ditto on the used price recommendations. I picked up a 2020 test ride rally for 10200 with new warranty and 120 miles on it. As for the recalls, don’t take anyone’s word for anything, they’re done or not done and personally I wouldn’t lay out a cent without the recalls done. Really just the wheel nuts and you can see if that’s done. Make sure the steering is tight and straight. Good luck!
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
    Feb 2021
    Mukwonago WI
    There’s a 20 new rally in IL for $10,600 all in plus tax / title.
    No idea why you’d pay $11,000 for used 20 w no warranty
    I’d want that warranty to sort it out if needed.
    Jan 2021
    Long Island, NY
    the 21 does have a few small changes... NVH in the CVT reduced 20%, they added a fuel cap, the axle tubes have caps covering the rusty bits... there may be more that I dont know about.
    2021 Sea to Sky
    2020 600 , gloss black
    Feb 2021
    Mukwonago WI
    21 has larger gas tank
    Jul 2020
    Florida
    Quote Originally Posted by Huggytree View Post
    My 2020 Rally has 5.3 gallons, same as the 2021.
    2020 Can-Am Ryker Specifications
    Engine: Liquid-cooled inline-two (600cc engine)/Liquid-cooled inline-three (900cc engine)
    Displacement: 600cc/900cc
    Bore x Stroke: 74.0 x 69.7mm
    Horsepower: 50.0 hp @ 7,300 rpm (600cc)/82.0 hp @ 8,000 rpm (900cc)
    Torque: 36.7 lb.-ft. @ 6,000 rpm (600cc)/58.3 lb.-ft. @ 6,500 rpm (900cc)
    Transmission: Automatic w/ reverse
    Final Drive: Shaft
    Seat Height: 23.6 in. (600cc)/26.5 in. (900cc)
    Rake: N/A
    Trail: N/A
    Front Suspension: Double wishbone w/ Sachs twin-tube coilover shock; 5.4-in. travel
    Rear Suspension: Preload adjustable; 5.9-in. travel
    Front Tire: 145/60R-16
    Rear Tire: 205/45R-16
    Wheelbase: 67.3 in.
    Fuel Capacity: 5.3 gal.
    Dry Weight: 594 lb. (600cc)/616 lb. (900cc)
    2021 Can-Am Ryker 900 Specifications
    Engine: 900cc, liquid-cooled Rotax three-cylinder
    Compression Ratio: N/A
    Fuel Delivery: EFI
    Clutch: Automatic CVT w/ reverse
    Transmission/Final Drive: 6-speed/belt
    Frame: Steel box-section single-cradle
    Front Suspension: Sachs twin-tube coilover shocks; 5.4-in. travel
    Rear Suspension: Sachs twin-tube coilover shocks, adjustable for preload; 5.9-in. travel
    Front Brakes: Nissin 2-piston floating calipers, 270mm discs w/ ABS
    Rear Brake: 1-piston floating caliper, 220mm disc w/ ABS
    Wheels, Front/Rear: 5-spoke aluminum; 16 x 4.5 in. / 16 x 6.5 in.
    Tires, Front/Rear: 145/60-16 / 205/45-16
    Seat Height: 23.5 in.
    Claimed Dry Weight: 616 lb. (w/o fuel)
    Warranty: 1-year BRP limited warranty w/ 1 year of roadside assistance
    Available: N/A
    Contact: can-am.brp.com
    2020 Can Am Ryker Rally Sport Touring Edition
    Apr 2020
    Olympic Peninsula, WA
    The question remains... What are the difference between the 2020 and 2021 Ryker RALLY?
    Jul 2010
    Las Vegas, NV
    Gas cap, as far as I can tell. I’ll ask!
    Joe Meyer
    Active Member RickD's Avatar
    Apr 2021
    Due South of Houston TX
    Quote Originally Posted by racer83l View Post
    ... NVH in the CVT reduced 20%...
    Noise, Vibration, Harshness. I learned something today.
    Dec 2020
    Mesa, AZ
    The number 0 was replaced with 1
    Jun 2015
    Ritzville, Wa
    Thank you. I didn't think about asking about the warranty. I just assumed that it had expired. I will look into the extended warranty. I usually get them when I make a car purchase. The warranty would make a difference,
    Keep in mind if the factory warranty is expired, you can't get the 3 year BEST extended warranty.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
