Results 1 to 6 of 6
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Default Carpet for Freedom Trailer
    We just bought a 2015 freedom trailer and was looking to line it with actual carpet.....not the plastic floor mat you can buy.
    Does anyone know if Can Am sells just the carpet insert? I can't find a part number for a carpet insert... just for the plastic floor mat.
    Thanks for your time and help!
    P.W.
    2019 Phoenix Orange RTL
    LED head lights, LED fog lights, Lidlocks, Brake light kit, Sway Bar, J&S Jack, Cat Delete, Akrapovic silencer, Idler pulley Kit, Gold Drain Plugs, Magic Mirrors, Bumpskid, Tires, Centermatic balancers, Wick-it Stage 1 tune, Convex mirrors, EBC Brake Pads, EBC brake Rotors, Speed Bleeders, M-2 Custom Shocks, Odyssey Battery, Tinted Windshield, Windshield Arm, Gps Ultimate Seat, Dual air Horns, Modesta BC05 Ceramic Coating, Redline 10w40 motorcycle oil, BRP Passenger arm rest, BRP hitch, Syderpop rock guard 2015 Freedom Trailer
    Mar 2013
    Maumelle, AR
    I don't think there was a carpet option for the Freedom trailer. You might have to make your own piece from a remnant.
    2020 RT Limited , Chalk
    Bryant, Arkansas
    Copperman is correct no factory carpet was ever available except the plastic/rubber one
    Cruzr Joe
    Mar 2018
    IA
    Okay...for some reason I thought I was a pic of the new trailers with carpet in them.....guess not Lol
    Thanks,
    P.W.
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    we bought a "outdoor mat" (4' X 5') from a local hardware store and cut that to fit. I made templates with several cardboard pieces and it fits pretty good.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Northern Kalifornia
    I did about the same as bcer960 did, and surprisingly it worked quite well. I bought a roll of 1/4" thick gray indoor/outdoor carpet from Lowes about the same size. It was large enough to not only cover the bottom but up the sides as well. For the curves on corners, I simply cut out "V" shaped pieces so the carpet would fit flat without overlapping. The carpet I used was rather stiff so there was no need for any adhesive to hold it in place. I also store my trailer standing up, and the carpet has never moved or collapsed because of gravity.
