Results 1 to 9 of 9
    Feb 2019
    Richardson,TX
    Default Battery terminals loose
    Six thousand miles and time for an oil change service. So off I go for a short ride. A couple of blocks from the house my Rallye dies. I restart and off I go. Coming home she goes into limp mode. Shop closed on Monday so Tuesday morning I limp to the dealer. He calls and tells my tat there aren't any codes but the battery cables are loose. They do a $360 total tune-up, check belt, new plugs, filters and oil. Hope to hell that fixes her for another 6000 miles.
    Feb 2020
    N. Wilkesboro, NC
    Star washer between the top of the bolt and the battery cable(s).
    Quote Originally Posted by MONK View Post
    :agree .... I've posted that bit of advice 50+ times ( or more ) ...... to the OP find a new dealer, they don't have your financial interests as a priorty ...... Good Luck .... Mike
    Dec 2020
    Mesa, AZ
    Those should never loosen on their own. If you never removed the battery I would question the dealer if they are the ones who assembled the bike and let them know if they proceed with the charge you will be doing business elsewhere. As well if you have never done your own oil and filter change you will save a ton doing this yourself. Dealership repairs do not necessarily mean you will have quality work done.
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Why blame the set-up dealer?
    Checking cables is a 6,000 mile item (not that I would take a Ryker 6,000 miles before the first oil change)
    I added stainless steel split washers at first service (1200 miles)
    http://www.operatorsguides.brp.com/O...9/619998EN.pdf
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    6,000 miles for new plugs?? They are supposed to last for 60K miles. Just saying.
    Danbury Connecticut
    I had a loose battery cable on my 2020 RTL just two months and 700 miles after I picked it up. I tried tightening the screw, only to find both terminals were as tight as possible.
    I also thought to blame the set up technician at the dealer.
    It turns out that on the negative terminal, the screw was just a hair too long (or more likely, the battery terminal was a hair too short). The screw was bottoming out in the terminal without completely tightening the cable. I put a washer between the cable and the terminal and retightened the screw. 6000 miles later, I've not had any issues.
    IBA #47122
    2020 RT Limited Asphalt Grey
    May 2020
    New Mexico
    If I posted 6,000 mile spark plug change intervals, pls advise where, so it can be corrected.
    Can-Am advises to replace standard plugs at 12,000 miles
    I would expect iridium to last 50,000 miles
    https://www.spyderlovers.com/forums/...rst-oil-change
    The below photo is of page 94/179 of the PDF manual, per this post 5 link:
    The only differences I recall from 2019 to 2020 is the engine oil fill amount.
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    First thing I do after a purchase (car - motorcycle - tractor) that includes a starter battery is add star washers, tighten down terminals, and give a good saturation charge. Then recheck at each service.
    Joe
    2023 F3
