Results 1 to 7 of 7
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default For Sale: 2016 Can Am Spyder RT Limited Chrome Edition $16500.00
    FOR SALE: 2016 Can Am Spyder RT Limited Chrome edition, Pearl White with black pinstripes, w/10k miles on it, for $16500.00
    Note: Odometer shows 5640, but the dash was replaced at around 5k, so really it has around 10k on it and this can be verified with your local dealer as it is indicated in the BEST Site as it was replaced under warranty.
    Upgrades:
    Installed Garmin Nuvi GPS
    Color matched back fender.
    Lamonster LED Headlights/Foglights
    Full Tricled Safety lights Package #3
    TRICLED Sequential Turn Signals
    TRICLED Bag Lights
    The Longhorn Mirror Turn Signals from Lamonster
    Baja Ron Swaybar
    Wolo Bad Boy Horn
    Lamonster Spyder cuff.
    Custom painted calipers in '69 Ford Mustang Grabber blue.
    It also has the Can-am Spyder Accessories trunk organizer.
    I also ran a 3.5mm aux wire from the trunk to the spydercuff so you can plug your phone in and listen to music from the handlebars.
    Upgraded Larger Brake Pedal
    Lamonster Belt Tensioner
    Also comes with a full cover.
    Foam Grips.
    New rear tire installed in August 2020.
    Garage kept, and I am the second owner. Located in Northern Virginia, less than 25 miles to Dulles Airport, fly in, I will pick you up at the airport and you can drive home from anywhere. Awesome deal with all the upgrades done for you!
    https://spyderforsale.homesteadcloud.com/
    Also check out the video at: https://youtu.be/Zfre4wuUYmg
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Jun 2018
    HAYMARKET,VA
    Default I should have added comes with CAN AM B.E.S.T. warranty through Sept 2020.
    I should have added comes with CAN AM B.E.S.T. warranty through Sept 2021.
    & It also has the RT Limited Trunk light from Can Am Spyder Accessories.com
    Quote Originally Posted by FINFAN3DP View Post
    Upgrades:
    TRICLED Bag Lights
    Baja Ron Swaybar
    Wolo Bad Boy Horn
    Foam Grips.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Sep 2020
    Platte City, MO
    September 2020, or September 2021?
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Possible View Post
    2021, thanks... Still screwin up the year, a month in!
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Default I should have added comes with CAN AM B.E.S.T. warranty through Sept 2021!!!!
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jul 2014
    Mint Hill, NC
    Barely broken in; should go quickly -- good luck!
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jun 2018
    HAYMARKET,VA
    Byke is sold. Thanks everyone!
    Baja Ron Sway Bar
    Key Cover from Ebay
