Bright
I fired them up tonight and they make the LED headlights look dim. But when the headlights are on " brights" and the auxiliary and fogs are on----- can you say daylight
Lew L
I am going to re-orient the LED in the auxiliary lights by 45* to see if it gets a flatter beam.
Update:
Trick LED got back to me very quickly ( even though I didn't buy from them ) and said I need to reorient the lights.GOOD customer service!!!
Originally Posted by Fearless
Did you make the mount or did the supplier have it available? I don't think that mount will work with the adjustable deflectors but it's a neat solution for the fixed deflectors.
Do you feel like these "washout" the turn signals as all being that close to them?
Ozzie Ozzie Ozzie
