Results 1 to 3 of 3
    Aug 2019
    Stoughton, WI
    Default F3 shock lengths
    Anyone here know if the overall shock lengths between the F3/F3S/F3L are the same? I've been in email conversation with Race Tech about shock builds. The Race Tech tech says they have build specs for both the F3 and F3L, but not the F3S. Still leaning toward M2, but covering all bases .. Thanks
    2022 RT Sea To Sky
    Apr 2020
    Edgerton,WI
    Thumbs up
    I have a set of new FOX shocks ( Can Am 219400733) for my 2019F3L
    C-C eyelet. =450mm. 17 3/4
    When installed C-C =420mm
    2019 F3L , Covid Blue
    Sep 2008
    TX
    The part numbers for the upper and lower A-arms, and the frame are the same for F3, F3-S, F3-T and F3-L models, given the same color. The shock and spring numbers are different, presumably for different performance characteristics (damping and weight). The center to center distance should be the same.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
