Results 1 to 4 of 4
    Apr 2020
    Huntsville AL
    Default 2020 RTL Tp Storage Case (Cam Locking Mechanism)
    I need some help, I have to remove the rear top case to travel with my RTL in my toy hauler. The top case removes but the quick cam switch in the bottom of the case is VERY hard to turn. Is there anyway to loosen it up to make it easier to detect from the bike. I didn’t want to try anything until I posed it on the site. Thanks in advance.
    Dec 2013
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Oct 2020
    Arizona
    https://www.youtube.com/watch?v=-9IRDm2KrdU
    Also I think one of this would work.
    https://www.amazon.com/Perko-12487-8..._t1_B00WFJ3E7K
    I would be taking a piece of aluminum flat bar about 1" x 8" x 1/4", put about a 30 degree bind at around 3" , drilling two 1/4" holes, bolting on two 1/4-20 bolts with smooth shanks, and then cut the heads off with a cutoff wheel in my Dremel tool. Then put a couple layers of shrink tubing on the bolt shanks, and a piece on the "handle" end also. Chris
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Yeah, the first time I tried to take my top case off it was a real bear to turn. I too used a rubber edged clamp to twist it off. Locking it was much easier. That recess in the dial wasn't deep enough to get a good grip on it. After taking it on and off a few times however, I can now twist it with one hand. Guess ya just had to break it in.
    GLIDE-ON>>>>>>>>>>>>>>
    "Blue Belle" 2021 RTL Chrome in Petrol Blue
    2021 RTL Chrome , Petrol Blue
