Page 1 of 3 123 LastLast
Results 1 to 25 of 67
    Apr 2016
    Albany NY
    Default 2020/21 redesigned front drive sprocket
    I won't replace it till the beginning of March so I don't have anything to compare it to. But this is the redesigned one hope it's quieter!
    Feb 2019
    Portland, Oregon
    Not having anything to compare it with...what's different about it? Will it retrofit all 1330s? Got a part number?
    indpls in
    the part number is stamped into it with date pic 2
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    /*humor on*/ That's a new special coating that sheds red dust... /*humor off*/
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Apr 2016
    Albany NY
    Don't know what's different was redesigned to get rid of the whirring humming whistling noise
    Feb 2019
    Portland, Oregon
    Did I read that part number correctly? 105563244?
    Anyone know if it retrofits all 1330s?
    Apr 2016
    Albany NY
    Oct 2020
    Arizona
    Well BRP parts catalog for 2021s built after Sept 2020 list part number 705503239 and before that date part number 705502134. So is the 705503244 a third version of the part?
    Apr 2016
    Albany NY
    This is what I ordered but you see what came
    To my eye, and it's difficult to be certain because there is no common scale with either of the two sprockets, it appears the holes may be larger and there is obviously no raised ring on the inner circumference of the flange on the 10/20 sprocket. Larger holes probably would reduce the tone of any whistling (think flute or penny whistle notes). Just a WAG on my part. The date on the 705503244 is obviously later than the Sept 20 date mentioned in the parts catalog and I thought the "new" '21s were supposed to begin production in Jan '21. Ergo a part with a 10/20 manufacture date would be available for 1/21 production. Another WAG.
    Oct 2020
    Arizona
    I think OP's pictures are of the back and front side of the same sprocket?
    Very valid point, particularly noting the wrinkles in the bolt bag. Question then would be what do the new and old ones look like side by side.
    Feb 2019
    Portland, Oregon
    Yes, photos with the new and old pulleys side by side would be very helpful. Hint, hint.
    Mar 2013
    I have the same sprocket to put on my wife's 2018 F3 tomorrow. I will take a picture of the new and old sprocket side by side. The only thing I noticed was that the new one is painted, but I did not measure the hole sizes. The new one does have made in the USA printed on it. I will need to look to see if the old one has that as well.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2013
    Side by side pictures.
    Holes are the same size. Looks like the flange to sprocket hub is sloped compared to the old one.
    Feb 2019
    Portland, Oregon
    Thanks for the photos. Am I wrong, or is the new one larger?
    Quote Originally Posted by PW2013STL View Post
    Holes are the same size. Looks like the flange to sprocket hub is slopped compared to the old one.
    " SLOPPED " ...?????? Thanks .... Mike
    Mar 2013
    Same size. The clean painted surface gives the illusion it's larger.
    Oct 2020
    Arizona
    I assume that in the third picture the old one is turn 180 degrees? Are the splined hubs the same length or is the new one wider?
    Mar 2013
    One to many beers so I got 2 p's��
    Mar 2013
    Quote Originally Posted by Snoking1127 View Post
    Correct!
    They are the same.
    Sep 2020
    Central Oregon
    When's the whistle test? Did the spline fit feel the same?
    Spyder Tryke Pylot
    Mar 2013
    Quote Originally Posted by ButterSmooth View Post
    The fit was good, but I don"t know if it"s better than a new old stock pulley. The weather was not the best for a ride. The spyder needs to get a bath frist as it has 3 months of dust and dirt covering it
    Sep 2020
    Platte City, MO
    Plenty of anti-sieze on the splines prior to assembly?
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Mar 2013
    I used moly paste. Honda 77 assembly lube. 60% moly.
