Results 1 to 13 of 13
    Aug 2019
    Stoughton, WI
    Default Race Tech Suspension
    While (still) awaiting a reply from M2, I reached out to Race Tech about suspension for my F3S. Got this back:
    Hello Jeff,
    We do have shocks available from our G3-S custom shock line. They are built to order and setup for the rider and riding style specifically. The shocks come in our IFP with rebound and preload adjust option. The rear has the option for Hydraulic preload. Price for the front pair is $899.99. And the rear starts at $799.99.
    Let me know if you would like more info or have any questions.
    Regards,
    Jeff Zeliadt
    G3S Department
    Having a couple Race Tech vendors near by, I might have to dig a bit deeper...
    2022 RT Sea To Sky
    Sep 2020
    New Jersey
    I have the M2 shocks on my f3ss. They are amazing at how much better the bike rides. Price will be around the same as the racetech after the spyderlovers discount. I have helped friends install many different brands of shocks on four wheelers over the years. Holding the m2's, you can feel the quality of the materials. I know that might sound cliche, but you will only understand when you have the oem fox podium in one hand and the m2 in the other. Call Marcus directly and ask about setup and spring rates to suit YOUR preference. I ride aggressive. The open road is not a smooth race course. Too stiff and potholes and manholes are jarring. Choose your ride while talking with the man building your shocks. That will not occur with any other manufacturer. Enjoy the ride!
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Quote Originally Posted by Time2ride View Post
    RIGHT ON!! M2 Shocks, OUTSHOCKING the Competition every day.
    T.P.
    Jun 2019
    Deltona FL
    $800 bucks for 1 shock?? I think I'll find something a little more reasonable.......
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    I've used them on both of my RTs and they are very good and of a very high quality. When I needed one rebuilt (my fault) it was done in a very reasonable amount of time. When it's time to replace the ones on my new 2020 (and it will be around 30K miles), I'll spend the money again to do it right with Racetech.
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    I have Race Tech Shocks front and rear...and recently installed a Baja Ron Sway Bar... the Ride/Handling is Fantastic!!! Worth every penny!
    Aug 2019
    Stoughton, WI
    Do your shock springs have any I.D. numbers on them to identify spring rate??
    2022 RT Sea To Sky
    Oct 2017
    covina california
    I'll look and see
    Apr 2012
    Florida
    Hey Troop. Did you ever hear back from M2? Tom
    2020 Petrol Blue Metallic RTL
    Oct 2017
    covina california
    There's no numbers on the springs
    SoFlo
    Quote Originally Posted by 308gunner View Post
    Likely Eibachs. Especially if a sort of metalic blue. But could be Hyper coils also.
    Many tuners these days do not want to share and will wipe away the spring spec info.
    Guessing with Spyders having so much automotive roots, BRP likely uses Eibach springs, ordered special in regards to color and an oem PN.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Tango View Post
    I actually called and had a good conversation with Marcus. Phone contact is best.
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    Via a message from Race Tech, I was advised that, with my weight and riding style, the Race Tech spring rates would 'likely be":
    Front: 8.5Kg/mm
    Rear: 9.8 Kg/mm
    Don't know if my math is right, but according to Marcus (M2) , the stock F3T spring is around 200lb/in. That's around 3.6Kg/mm. Hmmm
    2022 RT Sea To Sky
