Results 1 to 13 of 13
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Default Axle Nut on 2016 RT
    A little background first. I removed the plastic protectors underneath the engine. No problem with anything. Went for a long ride this weekend. When I came home I smelled what appeared to be burning rubber. I check the belt again the rear pulley. I can see where it has worn the paint off. I ain't as strong as I used to be, but how the heck do you bust the axle nut without busting myself? I want to try an re-align.
    Sep 2020
    Platte City, MO
    I used a 25" HF breaker bar to loosen mine. They are upwards of 160 lb.ft. I do believe.
    Oct 2020
    Arizona
    To start you need two 36mm wrenches and/or sockets. I ordered this 18" long big boy 36mm end wrench and have a 36mm socket for the oil filter. I have used my long handle torque wrench for jobs that need more leverage or I have a pipe that fits over my breaker bar.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Harrington, Australia
    Yeah, Possible is correct re torque setting, Bangorbob. 160lbft. They upped it in around 2013 from 90 lbft. I needed a looooong breaker bar, and had to buy a new torque wrench.
    HeliBars Handlebars
    Kenda Kanine rear.
    If you don't have a torque wrench that goes over 160 lb-ft get a 36 mm extension wrench. They're available as VW or HD wrenches. With the extension you can easily get 160 lb-ft torque on the axle nut by taking the wrench to something like 110 to 120 lb-ft torque. Do a search here, or on Google, for torque multiplier wrench.
    Jun 2018
    Pahrump NV
    Thanks to all. I ordered a 36mm box wrench and give it a try.
    Sep 2020
    Platte City, MO
    You'll need two wrenches, as the bolt will spin if you only turn one end. But I assume you already have the socket.
    Jun 2018
    Pahrump NV
    Thanks for the info. My brain must have went blank for a while. I returned the 36mm socket NOT THINKING that the axle will turn. I'll just go buy it again. I love getting older as it gives me an excuse to act dumber. (I talking about me-nobody else)
    Sep 2020
    Platte City, MO
    Well, at some point you get the joy of solitary Easter egg hunts, because you can hide your own eggs.
    Jun 2018
    Pahrump NV
    So true.
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    I thought I heard people saying
    The older you get the wiser you get, not dumber.
    Cheers.
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    Sep 2020
    Platte City, MO
    Those are old people you're hearing that from, and they forgot how it was supposed to worded.
    Quote Originally Posted by Bangorbob View Post
    Thanks for the info. I love getting older as it gives me an excuse to act dumber. (I talking about me-nobody else)
    Hahahaha..... well, you could easily have been talking about ME, Bangorbob
    HeliBars Handlebars
    Kenda Kanine rear.
