Dual-Fill 0-30 (balanced air filling for front tires)
This is a set of tubing, combined with quick-connect Schrader fittings and a high-accuracy, low-pressure air gauge, that allows you to simultaneously fill both front tires of a Spyder to exactly the same pressure. Note that this is the low-pressure version and must be used with a hand pump or regulated low-pressure compressor, not with air compressors running at over 30 psi. If you are running car tires at lower pressures on the front of your Spyder, you really need one of these.
Bought this new from CNC Machines about two years ago. Works great and good very cosmetic condition.
Selling for $45, shipping by USPS Priority Mail to CONUS/AK/HI included. PayPal preferred. If interested, PM me here or email [cjshelton . . . AT ----gmail DOT ___ youknowthesuffix].
current ryde: 2017 RT-S
previous bikes:
1975 Yamaha RD 200, 1978 Honda CX 500, 1980 Yamaha SR 500, 1982 Kawasaki GPZ 550,
2005 Suzuki V-Strom 650, 2006 Yamaha FJR 1300, 2015 Kawasaki Versys 650LT
If the snap fittings on the ends simply snap on to the valve stems, I'll take it. If I'd need add'l parts, I'll pass. PM me to let me know, please.
They're quick-connect fittings, but I wouldn't say they just "snap" on. You push them firmly onto the tire valve from the base of the brass fitting. To take them off, you hold on to the base and pull back on the outer brass sleeve. It's easy and quick once you get the trick of it, but it does take both hands.
previous bikes:
