Results 1 to 20 of 20
    Jan 2021
    Goderich, Ontario, Canada
    Default Wolo air horn for 2020 RT-L
    New forum member, and new Spyder owner. Has anyone replaced the rather lame stock horn with a Wolo or other air horn ?
    I haven't yet searched under the plastic to find the stock horn, but I was wondering about putting the air horn out front in one of the air intakes for the rads.
    I don't know what support may be under there, or if it's possible, but any feedback would be appreciated. THX.
    Sep 2020
    Middletown, NJ
    There's a thread on this forum on how to do the wolo. Try the search in upper right.
    The horn is reached from underneath under plastic plate on the right side (sitting in saddle), easy access.
    2020 RT base , Chalk White
    https://spyderpops.com/2020-up-can-a...und-of-safety/
    Harvey provides complete, easy to understand instructions too.
    Jan 2021
    Thanks guys, looks like replacing the stock horn in its place would be a lot easier than trying to hang the Wolo out front.
    Jan 2021
    OK folks, I finally got the Wolo mounted out front, where I wanted it. Still too cold in my garage to do the wiring, but I plan on 12 ga. wire from battery to relay, relay to horn, and all grounds. I'm going to tap the existing horn Positive wire and use that to trigger the relay for the Wolo. Leave the stock horn where it is, the more sound the better, right?
    Sep 2020
    Middletown, NJ
    12 ga wire is way overkill for any 12v accessory! 12 ga can carry 20 A @ 120 V (2400 Watts). Even heated gear uses smaller (16?) Your horn wire doesn't need to be larger than 18 IMHO.
    Sep 2020
    Platte City, MO
    I can't say I agree with 18 gauge wire. I use 12 gauge and 14 gauge wire normally for my aftermarket add-ons. I'd never
    go as small as 18 gauge. But that's just me. From what I've read 10-15 amp draw normally recommends at least 14 gauge
    wire. I didn't see anything about wire as small as 18 gauge.
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    I put on the Wolo Big Bad Max horn. It wasn't easy to install, and included making my own bracket and cutting out the can am one, but It's installed, and it is like a big rig truck horn!
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Jan 2021
    O.K., so first - I didn't realize that the stock horn is wired live all the time, even with the key OFF. So now I can't figure out how to run BOTH horns at the same time. So I just disconnected and extended the stock horn wires through a small loom out into the frunk, and hooked them up to the trigger terminals on the horn relay on the floor of the frunk. Air horn works great.
    Jun 2011
    Alamogordo, NM
    Wire gage is a function of Amperage, not Voltage. What is the amperage draw if a Wolo? Use a stranded wire due to its better vibration resistance. I would recommend a minimum of 16 Ga copper stranded.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Feb 2016
    Quote Originally Posted by FINFAN3DP View Post
    Did you use the supplied relay?
    2020 RT Limited , Marsala Red
    Jan 2021
    Yes, for the Wolo I mounted out front. Relay sits on the floor of the frunk, under the liner.
    Dec 2015
    Oakley Utah
    I put on the Wolo Big Bad Max horn. It wasn't easy to install, and included making my own bracket and cutting out the can am one, but It's installed, and it is like a big rig truck horn! 20210224_171209.jpg 20210225_133234.jpg
    Is the horn pointed up? I can't tell from the pics.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    I can't say I agree with 18 gauge wire. I use 12 gauge and 14 gauge wire normally for my aftermarket add-ons. I'd never go as small as 18 gauge. But that's just me. From what I've read 10-15 amp draw normally recommends at least 14 gauge wire. I didn't see anything about wire as small as 18 gauge.
    A lot of the wiring for lighting on the Spyder is 18 gauge, and many LED add-ons are 22 gauge.
    Those larger gauges are for heavy loads off the battery. It all depends on the amperage draw of the load. AND, we are talking about 12vdc systems, not house wiring.
    (NOTE: I tried to post a 12vdc chassis wire gauge chart here but once again the system is preventing me from posting jpegs)
    https://mgispeedware.com/wire-size-chart/
    2014 RTL Platinum
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I just bought the dual horns that slingmods is offering. I'll be installing them this weekend. I put them on the wife's Ryker and boy are they loud.
    2021 RT Base - Petrol Blue
    Dec 2015
    Oakley Utah
    Quote Originally Posted by RayBJ View Post
    2014 RTL Platinum
    Mar 2015
    forrest above Reno, Nv
    Hi Pete, I also had some trouble posting the water pump pix here. I found that when I lowered the resolution of the pix --- it worked.
    2014 RTS , Circuit Yellow
    Jan 2021
    My Wolo outlets are pointed down, just ahead of that 'wing' that comes down, and the rest of the horn is wedged behind that.
    Jun 2018
    HAYMARKET,VA
    Default nope.
    There was no relay, plug and play. Easy wiring, matches the oem horn.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    No, horn opening is pointing towards the right towards the baja ron bar.
    Baja Ron Sway Bar
    Key Cover from Ebay
