Results 1 to 13 of 13
    Sep 2015
    Cemtral ohio
    Default Should my Frunk lid pop up when released?
    Just a quick guestion....when you release the frunk lid should it pop up? I have to hold the key in the unlock position & open the lid.......i have seen others that pop up when the key is turned......is there an adjustment that i need to make?
    Bossier LoUiSiAna
    Believe latch did not have a spring before 2013 if can be added.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    I had a 2011 RTS. The lid popped up. You may need to shim or bend something. Can't tell without seeing it. Take you time and pay attention to what it is doing. You'll figure it out.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Quote Originally Posted by Headwrench View Post
    I found a very small " coil spring " ( at McMaster-Carr ) that I mounted on a thin piece of alumin. sheet metal .... I put it under the large frunk hinge on my 14 RT ( they will work with any hinges of the same design ie. most RT's ) ..... it provides enough pressure to open the lid about 2 inches. ... When I was vendoring I sold dozens X's 3 .....Mike
    Sep 2020
    Platte City, MO
    Peggy's 2013 ST-S frunk lid just moves a skosh when the latch is released. Definitely doesn't "pop" up, but it does move.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Jul 2014
    Mint Hill, NC
    If my latch mechanism is perfectly clean and lubed with a little white lithium grease it will unlock and sit there until I lift it. Otherwise, with my long arms I turn the key with one hand and lift the lid with the other. I thought of doing what Mike has done but riding has always been more important.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Nov 2020
    Lincoln, Nebraska
    I have a 2016 RT SE6 and when you turn the key to open it doesn’t move, I have to lift it up.
    Sep 2015
    Chilliwack, BC. Canada
    My 2014 RTS unlocks and you can release the key and then go and lift the frunk lid. Been that way since new.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Feb 2020
    N. Wilkesboro, NC
    I had to lift the frunk lid on my 2018 RTL whilst I was holding the key. I don't know if it had a spring or not. The lid on my 2021 RT pops open just fine and it DOES have a spring.
    Apr 2020
    Upstate NY
    Very important to keep that latch lubricated. Mine was very stiff when latching or unlatching prior to spraying some silicone lube on the latch.
    Current Rides:
    2015 Spyder ST-S SM5
    2016 Honda Gold Wing ABS/Navi
    2022 Royal Enfield Classic 350
    2021 Royal Enfield Himalayan
    Idaho
    There is some adjustment in the latch. The lid might not be closing tight enough to squash the seal around the frunk. When the latch is released the pressure of the seal will raise the lid. Mine doesn't really 'pop' up, but it does come up loose from the latch. Your challenge will be to find the 'sweet' spot for the latch so that it allows the lid to rise up but not hold it down so tight that the latch doesn't want to release. Too tight latch settings have caused release cables to go south, and replacing them ain't a 5 minute fix!
    2014 Copper RTS
    Sep 2015
    Cemtral ohio
    Thanks guys......im gonna work with it tomorrow & see what i can figure out....thanks again
    Nov 2016
    Upstate NY
    I have one of Blueknights springs. It works very well. I am sure you can get a similar spring that will work at Lowes. You could mount it near the hinge or near the latch depending on the type of spring. If you have an organizer attached to the underside of your hood, you will need a spring assist.
    2021 Sea to Sky RT , Highland green
