Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 73
  1. #26
    Oct 2020
    NW INDIANA
    I just installed a new bar on my 2015 RT last week and could not believe the difference in handling. With standard suspension it felt like it was going to roll over when riding on a high crowned road in a cross wind. Because the temperature was near freezing, the test ride was short, but I am sure this little modification will add a lot of comfort to my ride next spring.
  2. #27
    Aug 2020
    Ohio
    used your tubing trick when I did my Baja Ron Sway Bar and it was real slick. Got the bolt thru on the 1st try. Getting the plastic back together took some trial and error but it was worth it. Thanks RICZ
  3. #28
    Active Member FIRECAT's Avatar
    Aug 2010
    WINDSOR,ONT,CAN
    A friend of mine put Baja Ron sway bar on his F3 limited in Illinois! Myself living in Canada with shipping and exchange I will be well into $400 for it I don’t think I can justify the cost I just crank the tighter spring rate on my front shocks which makes it a stiffer more compliant ride and less pitching to the outside of the corner pretty much effectively doing the same thing I am now going around corners very quickly and very stable just crank up the shocks guys your thoughts? Again $400 is a lot of money just to Eliminate wait transferred to the outside when tightening the shocks did the same thing! I have a Pontiac Trans Am that has a very stiff firm suspension that does the same effect that’s why sports cars are very stiff and firm
    SNOWMOBILING ON PAVEMENT!!!
  4. #29
    Sep 2020
    Platte City, MO
    Yeah, not such a big deal as long as a smoother ride isn't that important. With the BajaRon anti-sway bar, you can get a more compliant ride
    without sacrificing ride quality. And a stiffer ride doesn't necessarily mean better handling in all conditions, as you can get such a stiff ride that
    the tires will be not able to follow the contours of a rougher road when the springs are cranked up. Smooth roads, yes, but how many really smooth
    roads do you come across? The last thing you want is the vehicle to go skittering around on bumpy corners. That's why better handling sports
    cars also have substantial anti-sway bars. Best of both worlds.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
  5. #30
    Feb 2019
    Portland, Oregon
    FIRECAT.....What was your process for tightening the shock springs? My F3L has adjustable shocks, but I can't budge the rings. Yeas, I have the two spanners, but maybe not enough muscle. Did you remove them and compress the spring?
  6. #31
    Aug 2018
    Chicago
    jack the spyder up to get tension off springs just enough makes it easy
  7. #32
    Aug 2010
    WINDSOR,ONT,CAN
    Yeah the rings were very tight had a hell of a time but I managed! get some strong musclebound kid to help you also take the wheels off the ground and take all load off springs! I saw a vast improvement! Also being a limited the shocks are very soft for smooth rides! I know what you’re saying Howard about compliance and even shock travel is cut back but again roads are way smoother than the off-road snowmobile trails I’m used to or even ATV dirt bike trails or even waves out on the lake on a PWC
  8. #33
    Aug 2010
    WINDSOR,ONT,CAN
    So I’ll ask of of you again is the Ron Baja swaybar worth $400 I think it’s 280 your money?
  9. #34
    Sep 2020
    Platte City, MO
    Well, I don't know that I would pay $400 for it, but it was worth the $288 I paid. The body lean on Peggy's Spyder was awful
    and the BajaRon anti-sway bar worked like magic. Basically put paid to the body lean.
    But don't forget, I'm a cheap bastid.
    Peggy and Howard
  10. #35
    Apr 2019
    Clinton, MS
    The difference between an anti-sway bar change and simply using the adjusters to raise the ride height are enormous. Think about it.
  11. #36
    Active Member Northofthesix's Avatar
    Sep 2019
    Leamington, Ontario, Canada
    Firecat I am in Leamington, Windsor's warmer cousin I put a BajaRon swaybar on my 2018 RTL and the difference was stunning.... even at the $400CDN for the bar, and about $75 for the dealer to install (book rate was 40 minutes, actually took him 2 hours... I was on the winning side of the calculation for once!), it was a HUGE value to me. No more skittish handling in crosswinds, no more dipping going around corners, to me it handles like it's on rails!
    You can't get there from here....
    Mods and Tweaks:
    Showcrome Trunk Rack
    Showcrome LED Trunk Light
    Garmin 390LM
    Spyderzone Floating Hiway Boards
    Spyderzone Mount Dash Bracket
    BajaRon Antisway Bar
    Showcrome full-size brake pedal
    Spyder-2-Go Driver Cup holder
    Ram X phone mount
    SpyderExtras 12 volt Docking Station
    BRP Driver Backrest
    Monster 4K Action Camera
    Spyderzone LED Fender Mount Spotlights
    CASA LED Headlights and Foglights
    2018 RT Limited , Ashphalt Metallic
  12. #37
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by FIRECAT View Post
    Yeah the rings were very tight had a hell of a time but I managed! get some strong musclebound kid to help you also take the wheels off the ground and take all load off springs! I saw a vast improvement! Also being a limited the shocks are very soft for smooth rides! PWC
    Thanks a ton for this info. One more question; Will tightening the springs raise the front a bit?
  13. #38
    Apr 2019
    Clinton, MS
    Thats exactly what it does.
  14. #39
    Sep 2020
    Platte City, MO
    As you adjust, tighten that is, the springs it will cause the shocks to extend farther with the same amount of weight
    on them. So yes, the ride height would increase, the ride would be a bit harsher, unless it was too soft to begin with.
    The lean will lessen because the springs won't allow the shocks to compress under load as much.
    Peggy and Howard
  15. #40
    Dec 2013
    Quote Originally Posted by Possible View Post
    But you really do want to watch out!! Increasing the static loaded ride height WILL increase the Positive Camber and that can impact your wheel alignment/steering geometry adversely... unless your ride height was already a fair bit too low and you are simply returning to the recommended static loaded ride height as you raise it, of course. And if you 'lift' the ride height too much, you'll also be reducing the available suspension down travel (cos you are already getting up near its full length) and that really is something you want to avoid!! It can make for a very uncomfortable ryde, if not a dangerous one!
    I don't know if they still do it (altho I suspect they do at some stage!) but back in the day, BRP used to do their wheel alignments with a 'fixed length bar' fitted in place of the shocks; so the suspension and steering geometry IS very much height critical, so playing with that height at all is just a bit chancy!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  16. #41
    Feb 2019
    Portland, Oregon
    Good - I need 'er up a bit higher here in pothole city. My DIY front bumper already saved plastic when I hit one.
  17. #42
    Oct 2020
    Arizona
    I wonder how high one wheel would have to be lifted to remove the sway bar. With one wheel down and the other up 16" would the bar come out at an angle?? I guess I could do a little Geometry and try to figure it out.
  18. #43
    Feb 2020
    N. Wilkesboro, NC
    FYI---The Limited trim has the same suspension as the lesser trim.
  19. #44
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Snoking1127 View Post
    I wonder how high one wheel would have to be lifted to remove the track bar. With one wheel down and the other up 16" would the bar come out at an angle?? I guess I could do a little Geometry and try to figure it out.
    Track bar....do you mean sway bar? If so, you need to get that 22" from bar to floor and no amount of fudging will do it.
  20. #45
    Sep 2020
    Platte City, MO
    ^^^^^^^^^^Yep, what he said.
    Peggy and Howard
  21. #46
    Oct 2020
    Arizona
    Sorry being a 4x4 truck owner with a solid front axle I have track bar in my brain.
    If the trike is lifted on one side the 22" extends out to the side at an angle, not straight down was my point.
  22. #47
    Sep 2020
    Platte City, MO
    Nope, it has to go down not out, so 22 inches from the floor is pretty close, maybe a bit more.
    Upon reflection, and reading the post below, I will change my opinion. It probably wouldn't have to be
    raised quite as much since it could move out to the side some, but still pretty high.
    Peggy and Howard
  23. #48
    Apr 2019
    Clinton, MS
    You are correct in the fact you would not have to raise it up as much. I think it might be higher than you think. Your pivot point to get the bar out is very near center between the wheels. You probably would benefit from starting from having both wheels on ramp position.
  24. #49
    Oct 2020
    Arizona
    Well today I did some prep getting ready this morning putting the Spyder up on blocks so I could remove the connection links between the A-frames and the OEM sway bar. Late this afternoon the new bar showed up, and I installed the new links and put a bolt hand tight on one end. I had a wooden dowel sitting on the mancave bench that worked great to hold the spacers in place to push the bolt in. So that step is done. In the morning I will remove the panels and another guy in the RV resort is coming at 10 with his truck and ramps so I can drive up and swap out the bars and then will put it back on the blocks to put everything back together. So by 11 or 12 tomorrow it should be ready to go.
  25. #50
    Nov 2018
    N.E. Ohio
    There’s a lot of good info on here. I have the Rally and my weight at the time was about 250lbs. From the factory setting I could just about bottom it out by sitting on it and bouncing on it. I cranked the front shocks up 2 1/2 bars each and it does corners very nice. Like already said, I sacrificed a smooth ride, but it was worth it to me. That said, I’ll be buying a BajaRon sway bar and links probably in spring. I’m working on some other modifications that will keep me busy for a while. cueman
