Page 1 of 3 123 LastLast
Results 1 to 25 of 73
    Nov 2020
    Pa.
    Default BaJa Ron’s sway bar install
    I ordered Ron’s sway bar this morning for my 2020 RTL, afterwards I started taking the bike apart to take the OEM one off. From a couple vids I’ve watched (not for the 2020) I was expecting a lengthy process. To my surprise it took 15 minutes to take the OEM links and bar off. You start with 2 plastic panels underneath one on each side, each has 3 push pins and 1 screw and that’s it, the bar is right there in front of you. 2, 10mm bolts in each link. 2 more 10 mm bolts about 6” in from the links on each for clearance to tip the bar down on each side and it’s ready for Ron’s. The hardest part is you have to have the bike front end at least 22” high to get the bar out. I was shocked at how easy it is.
    And I always thought the hardest part was waiting for the new bar to arrive!
    Feb 2019
    Portland, Oregon
    It's easy to install a Bajaron sway bar, even an 84 year old can do it.
    Feb 2020
    N. Wilkesboro, NC
    blacklightning and I installed mine. Probably took us 40 minutes but part of that was us 2nd guessing each other. I think the hardest part was getting those washers to stay in place long enough to get the bolt through everything. Getting the new delrin (?) bar "holders" (I don't know what they're called but I'm referring to the (2) pieces that fit around the bar and into the frame) in the frame was a bit frustrating, too. All in all, it wasn't bad. I've watched videos on installing the sway bar on the previous generation RTs. No, thank you. It took Pierre (who works on bikes all the time and has an actual lift) (2) separate videos just to get through it.
    Feb 2019
    Portland, Oregon
    I held the link spacers in place with a piece of neoprene tubing that is a friction fit in the holes. I then cut it flush with the washers. When the holes are all aligned, the bolt slips through and shoves the tubing out.
    Oct 2020
    Arizona
    Yep mine shipped today!
    Quote Originally Posted by MONK View Post
    Duly noted. And we are working on a universal solution for this somewhat aggravating situation. Something along the lines of what RICZ did with the necessary components included in the kit.
    Sep 2020
    Platte City, MO
    I used a very small tip pair of needle nose pliers. Worked very well.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Oct 2020
    Arizona
    I will find out all about this next week. Maybe a drop of super glue or a couple spots of rubberized Welders Glue that I have on hand, if I can not easily find a piece of tubing the right size. Another guy in the park is going to bring by his truck and 8' loading ramps for me to drive up on when ready is slide out the OEM bar and slide in the HD one, then back down and back onto my blocks.
    Feb 2019
    Portland, Oregon
    Snoking1127.....I can mail the tubing pieces to you. Just say the word in a PM.
    Nov 2018
    N.E. Ohio
    RICZ, you’re not only a smart man, but a kind man also! That’s what makes this a good forum. What I have done in the past for like problems is to put a bit of grease in the freezer and it will get a bit tacky to hold hard to get to washers in place. Plus, it’s pre greased when done! cueman
    Sep 2020
    New Jersey
    When I installed my sway bar I used wax to hold the washers in place while still allowing some wiggle room. Grease will do the same job just a little messy. Wax sticks are used for lubricating drill bits when drilling steel and aluminum.
    Sep 2020
    Lakeland, FL
    Great post guys, my sway bar is on the way and I appreciate the suggestions.
    2021 S2S , Green
    Oct 2020
    Arizona
    Thanks for the offer, however I have lots of options available up to and including turning a wooden dowel in a lathe in the parks wood shop. A little dab of E6000 tacky glue I have will do it also.
    Active Member Supercrawler's Avatar
    Nov 2020
    California
    Should indicate the toque specs instead of a word SNUG tight. Especially manual said too much tight it will crack the aluminum space washer.
    Dec 2020
    North Eastern NC
    What does this sway bar do?
    Sep 2020
    Platte City, MO
    The stronger/thicker/bigger the anti-sway bar is, the better it will control body lean in corners without unduly affecting ride quality.
    BajaRon's anti-sway bar does a much better job at controlling body lean than the OEM.
    Peggy and Howard
    Sep 2020
    Middletown, NJ
    The sway bar links the front wheels together so when 1 moves up or down, it pulls the other side the same direction. This effectively takes away a lot of body lean so the can-am is more stabile on rougher surfaces.
    2020 RT base , Chalk White
    Nov 2020
    California
    This bar will preventing seatbelt.
    Sep 2020
    Platte City, MO
    Quote Originally Posted by Supercrawler View Post
    Eh???
    Peggy and Howard
    Feb 2019
    Portland, Oregon
    Bajaron's sway bar turns a good handling Spyder into a wild ass go cart. Yee Haw!
    Oct 2020
    Arizona
    I am hoping for a good handling Spyder turned into a senior's fun go cart. If we get another stimulus check, I will do the shock adjusters next.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Snoking1127 View Post
    I am way past being a senior - I am now an artifact.
    Nov 2018
    Trinity, NC
    Super glue works great!! Used it when I installed mine.
    Cheers
    Nov 2017
    Western Australia
    Yep, I am out 7 years out of warranty !
