Results 1 to 17 of 17
    Clinton, MS
    Default HF lift extension for sway bar install
    My Harbor Freight lift would only go about 16" in the air so I was a bit short when installing BajaRon's sway bar. Less than $5 and a quick trip to Home Depot for a 2 x 6 for a home built extension. Works great. Shook it pretty good while about 6" off the floor for a test. Here is a drawing of what i made. Held together with 3" long drywall screws.
    Jan 2020
    Hamilton ohio
    Pictures
    May 2018
    millsboro,delaware
    So you jack it up then put it on jackstands,drop it down and put your extension on?
    : 2017 RTL ORBITAL BLUE
    Clinton, MS
    Jack it up about 10" or drive it up on a set of ramps, add the extension go up to 21 + inches if needed.
    And here are a couple of pics for Estes
    Jun 2010
    Las Vegas
    Our yellow craftsman jack has extenders that come with it, so we do a two part lift, once into small jack stands, then add the extensions and bring it back up on the tall jack stands
    Now on a few occasions, when we are working on the road, I have forgotten to pack the extensions and we have had to make do with whatever scraps we could find. The extensions are much easier!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2020
    Western New Mexico (Thoreau)
    Thanks, great idea! Will have to build one before I order new sway bar!
    Oct 2020
    Arizona
    Got it ready to slide the old bar out and new one in and had a friend come by with his side by side ramps. Then back on the blocks to put it back together. Just a minute or two on the ramps.
    Mar 2020
    That’s a great picture! So glad you had the friend with the right ramps, nice and wide! Let us know what you think of the sway bar upgrade! I have a base F3, Have heard so much about how great it is, but am apprehensive at the improvement and price! Thanks
    Oct 2020
    Arizona
    Between the Federal Formoza AZ01 car tires and the sway bar, I am really impressed with the increase cornering and steady feel on the road now.
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    That's a great idea Ed. Will use it for my Craftsman lift when I do my install. Thanks for sharing.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Quote Originally Posted by Valkrocket View Post
    Works slicker than what I did. Raised the Spyder, set it on blocks, took the jack out, slid a pallet with the jack on top of it back under, and finished raising the Spyder.
    Feb 2012
    Spring City,Utah
    I just drive mine part way up on my car ramps and block the rear wheel. I have an old HR lift I used to use with my RSTD/RSV but have not used it with the Spyder. I think I will build this extension and try it. Thanks for the idea.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2020
    Hartwell, Ga
    Just wondering, has anyone tried an ATV/Lawnmower lift. I have one and it lifts real high but I'm not sure if the mechanism/lift itself would be in the way.
    Oct 2020
    Arizona
    You need a clear path below the sway bar to slide it to one side and swing it straight down with 22"+ to the ground to get the old one out and the new one back in place. As it passes over the top of the central rib that runs along the lower frame. It only needs to be that high a minute or two. The prep getting ready for rermoval and the final installation of the new one can be done at a lower height.
    Aug 2020
    Georgia
    I would also add that one needs to be careful about how it is lifted: AFAIK, and I haven't tested this, the emergency brake only works on the rear wheel. So if you have the front end lifted and then you decide to lift the rear end while the front end is in the air, the Spyder is going to go backwards.
    My understanding (correct me if I am wrong) is you either lift the entire bike from underneath the main frame and get the entire bike lifted up (front and rear at same time) or you lift the front end by itself (brake on) or you lift the rear end by itself (chock front wheels).
    Mar 2013
    Great idea!
    You could make it more secure by contact cementing a rubber pad to the wood serfaces. I did that to a 2x6 board I use. This makes the contact serface non slippery.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Clinton, MS
    Quote Originally Posted by PW2013STL View Post
    Great idea!
    That would make a nice addition.
