Results 1 to 15 of 15
    May 2019
    Mt. Juliet, TN
    Default Laser Alignment - Any comments pro or con?
    2020 F3-T with no apparent handling issues with ~3,000 miles. I read positive reviews about getting these three wheel vehicles laser aligned and that noticeable handling improvements usually are the results. Any comments pro or con?
    Apr 2020
    Janesville,WI
    Quote Originally Posted by seagravesg View Post
    The results are only as good as the person performing the alignment. Also, pricing seems to be all the spectrum. In short, yes.... it’s critical to have a machine properly aligned.
    Active Member RayBJ's Avatar
    Sep 2020
    Central NJ
    If you're tracking well in a straight line (no wander), you may be close enough to not 'need' the laser but it can only benefit handling if done right. I paid $100 in NY last Nov.
    Dirt bikes, 1982 Virago 750, 2009 MP3-500, 2011 Mana 850, 2013 & 15 Triumph Trophy SE, 2018 Triumph Tiger 1200, 2020 Spyder RT
    2020 RT base , Chalk White
    May 2019
    Mt. Juliet, TN
    Checked with dealer and they do laser alignment with BRP system = $375. Think I'll wait until I can run across Squared Away or ROLO, etc. These are two that report to be good services and no more pricey. And sometimes they are mobile.
    Sep 2020
    Platte City, MO
    Wow, $375 for alignment. Is it just me, or is that waaaay over the top?
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Active Member Woodaddict's Avatar
    Mar 2017
    Salisbury,NC
    YES, wait till you can ROLO equipment. take the spyder in some good turns with dry pavement, if you need to constantly work handle bars to keep a straight even curve, you will need ROLO align. after mine was done, easier to flow thru a turn with minimal movement of bar work
    Mar 2017
    Salisbury,NC
    squared away around $110-$130, if its good aligned they don't charge
    May 2017
    Mesa, Arid-Zone-A
    Sometimes you "don't know what you don't know". I had Joe (Squared Away) align my Spyder a few years ago. If memory serves me, I don't think they charge if alignment is not needed. A good way to tell is, if you can ride down the road using one finger on each handlebar without any wandering, you're probably OK. What I was experiencing is that I was always correcting my line of travel without even knowing. That resulted in more tension and fatigue especially in my shoulder and lower neck muscles. Before the alignment, I just thought everything was normal. After a correct alignment I was in Spyder heaven..... Jim
    2008 Honda GL1800/California Sidecar Trike
    Platinum Silver Satin 2014 RTL, SOLD
    Semper Fi
    Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Be aware that when its new rear tyre time if ham fisted Harry fits it your alignment is in jeopardy.
    Don't touch the adjusters and make sure the axle hasn't crept out of line when tightening the nut. Reason being the front wheels are aligned to the rear wheel not the frame.
    In theory an alignment lasts forever or until there are wear factors involved.
    That they don't come factory aligned is one of the seven wonders of the world
    2017 F3S Daytona , Circuit Yellow Metalic
    BRP doesn't do " lazer alignment " some dealers do have and offer it.... but it isn't from BRP ...... to the best of my past knowledge ..... Mike
    Default lazer alignment
    BRP didn't have a great track record on Spyders being " aligned " from the factory. .... I've owned three and only one didn't need to be aligned...... if you don't have it checked ( by the lazer method ) , it may handle OK , but if you see more Wear on the outside of the front tires .... it isn't aligned properly ..... really bad cases will show up at about 5,000 mi. Mike
    Active Member Snoking1127's Avatar
    Oct 2020
    Arizona
    My belt is running a bit closer then what people say it should. However before and now really with the Federal Formoza's it tracks very straight. I run Cruise Control a lot and just rest my hands on the handle bar grips, running mile after mile with very little input. I was going to adjust the belt gap a little wider, however reading cobwebs post I think I will leave it alone for now. The rear tire has a few thousand miles left in it.
    2018 RT Limited Chrome - Champagne Metallic - East Valley of Phoenix
    Magic Mirrors, 360 LED head lights, dual USB with volt meter, GPS, phone and drink holders, Formoza's, BajaRon sway bar, dash cam, foam grips, 7 Jurock WS, Ikea sheep skin, HW pegs and driver back rest.
    Oct 2020
    Arizona
    My OEM Kenda's came off at 7500 miles and looked to have very little wear. Which reminds me I have to get that out of the back of the truck. If anyone close by in the Phoenix East valley wants a cheap set send me a PM. I am in Gold Canyon.
    Mar 2017
    Try new tires first. The checkerboard tread pattern on stock Kendas cause it to follow every road irregularity there is.
    My Toyo fronts (thanks Mike) are phenomenal.
    Quote Originally Posted by Rattlebars View Post
    ..... What ( if any ) fitment issues did you have due to the very wide tread width ???? .... and if so what did you do to compensate ???? ...... those suckers will really PLANT the front end ...... Let us know how much the NANNY reacts .... Mike
