What is the Ryker Front Wheel hub bore size?
Does anyone know what the hub bore size is for the Ryker front wheels?
I just went out to the garage and measured the exterior of the hub on mine; it is 1.75 inch. The bore size (for the wheel) should be slightly greater. The inside bore of the hub appears to be 1.5 inch.
Assuming you need that info for wheel balancing cones, Marc Parnes sells these on their "Spare Parts" page: http://www.marcparnes.com/Motorcycle...Components.htm
COMBI Cone set for single-sided rear wheels on all Ducatis, 2010 and older Triumphs, MV Augusta, VFR as well as Spyder front wheels bored for a 1/2" shaft.
Still needs the shaft & bearings to complete the kit.
Nice to know that my VFR cones will work for the Spyder wheels. I'm thinking I'll need a longer shaft for the rear wheel though.
Need to do some measuring.
Peggy and Howard
Hers: 2013 Spyder ST-S SM5
Yes. get the long shaft. The standard length is too short.
Thanks! And yes I am trying yo balance them. But the page that is provided appears to be for a hand spin type balancer set up. I will be using an electronic spin balancer.
