Results 1 to 6 of 6
    Jan 2021
    TN
    Default What is the Ryker Front Wheel hub bore size?
    Does anyone know what the hub bore size is for the Ryker front wheels?
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I just went out to the garage and measured the exterior of the hub on mine; it is 1.75 inch. The bore size (for the wheel) should be slightly greater. The inside bore of the hub appears to be 1.5 inch.
    2019 Ryler Rally , Shock Yellow
    Sep 2020
    Middletown, NJ
    Assuming you need that info for wheel balancing cones, Marc Parnes sells these on their "Spare Parts" page: http://www.marcparnes.com/Motorcycle...Components.htm
    COMBI Cone set for single-sided rear wheels on all Ducatis, 2010 and older Triumphs, MV Augusta, VFR as well as Spyder front wheels bored for a 1/2" shaft.
    Still needs the shaft & bearings to complete the kit.
    2020 RT base , Chalk White
    Sep 2020
    Platte City, MO
    Nice to know that my VFR cones will work for the Spyder wheels. I'm thinking I'll need a longer shaft for the rear wheel though.
    Need to do some measuring.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Sep 2020
    Middletown, NJ
    Yes. get the long shaft. The standard length is too short.
    Jan 2021
    TN
    Quote Originally Posted by Tslepebull View Post
    Thanks! And yes I am trying yo balance them. But the page that is provided appears to be for a hand spin type balancer set up. I will be using an electronic spin balancer.
