Results 1 to 25 of 50
    Jun 2015
    Eldorado, ILL
    Default Rear tire air valve
    Is there any way to install another add on to make getting air in the rear tire easier?
    Sep 2020
    Middletown, NJ
    I tried 1.5in extension but it made contact with pully edge so I removed it. Next time I pull the tire I'll install metal angled stems.
    2020 RT base , Chalk White
    Jun 2015
    Eldorado, ILL
    thanks. Very bad design for the trike
    Feb 2019
    Portland, Oregon
    I temporally screw on a 2" extension to check and fill.
    Quote Originally Posted by BikerBob View Post
    When it comes time to replace your rear tire .... before the new one is mounted .... add an Angled steel Mtc. stem from " Kurveygirl " , about $10.00 ... I have done this on every Spyder I have owned. .... The first one I removed the old valve and patched the hole .... then I just left the Oem valve, and put the new one opposite it..... The new one should be put on the other side of the rim,( the disc side )and away from the raised part of the wheel so tire machines won't hit it ..... Mike
    Dec 2020
    North Germany
    do you have a photo pease ?
    2020 F3-S , pedalbox black
    Northern Kalifornia
    For the time being, you can use an air chuck used for airing up dual tires on a truck. It's the right length and has the correct angle to easily access the rear tire valve stem. The best thing about it is that you don't have to get down on your knee to air up your rear tire.
    Active Member BryanSD's Avatar
    Jun 2018
    South Dakota
    Thanks for asking this question. Every time I have to get on my knees to fill air in that rear tire...I wonder...am I doing this right? It shouldn't be that difficult.
    2017 Spyder RT Limited - Champagne Metallic Chrome
    - Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
    2021 Spyder RT Limited - Deep Marsala Metallic Dark
    - Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
    Aug 2016
    South Wales UK
    I have wondered if it would be possible to fit a valve into the side of one of the spokes, pointing directly outward. This is done on BMW machines and would make inflation much easier.
    Quote Originally Posted by Flier Tuck View Post
    Good idea, but there's no easy way of making that work on our existing rims! At least, not without drilling into/modifying the rim itself & potentially compromising the strength of that spoke.... and since the rim wasn't designed with that in mind from the get go, probably making it a little more difficult to achieve a good wheel balance too!
    Sebring, FL
    Following this thread for a good answer if there is one. Surely BRM could have done a better job on this one. If you are one of those 'old' seniors, try airing up that tire a time or two, it will sure test your religion. I mean, come on, proper air pressure is a safety thing, why make it so difficult? They could have angled the valve or something!
    Feb 2020
    N. Wilkesboro, NC
    ...you can use an air chuck used for airing up dual tires on a truck.
    That's what I use.
    My issue isn't so much airing it up but getting the valve stem in the small area where you can actually access it. This is one of the reasons why I got the FOBO 2. I don't want to have to move the bike forward inch by inch (releasing and resetting the parking brake, running around to the other side of the bike, repeating the process, etc) before every ride. I check the FOBO and call it good.
    For the rear I use one end of a dual fill hose with clamp-on chuck. Not that much of a problem to slip the chuck on and off unless you have gorilla size fingers.
    Feb 2012
    Spring City,Utah
    Until you can get your air valve moved or if your somewhere without the right sizes chuck, gonto the Harley store and get a stem extender as used foyr an Ultra. Harley has the same problem and have 6" flexable extention. Costs about $10.00. I keep it on the Spyder with my air gauge.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2014
    Benson, NY
    This is one way to cure the problem like others have said.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Until you can get your air valve moved or if your somewhere without the right sizes chuck, gonto the Harley store and get a stem extender as used for an Ultra. Harley has the same problem and have 6" flexible extension. Costs about $10.00. I keep it on the Spyder with my air gauge.
    Here's a link to the extension: https://www.harley-davidson.com/us/e...-8;sp_staged=0. I bought one as soon as I bought my Spyder and shortly after I bought a Harley emergency compressor that has an identical extension with it.
    Northern Kalifornia
    Quote Originally Posted by Bensonoid View Post
    That would be it!
    As MONK mentioned, I also run FOBO's, and therefore I know at any time what my tire pressures are. If you have any experience with FOBO's you know that these spyder front tires have very little air in them, volume-wise. Merely the act of checking their pressure can allow enough air to escape and drop the pressure by a pound or more if you're not careful. In reality, a pound or so is not extremely critical. Because of simple ambient influence, your front tires can change one or two pounds all on their own while riding your spyder. But if you are like some of us who are overly anal, a two-pound difference can be worrisome. The rear tire can heat up to as much as four pounds from cold to hot after a half hour or so of operation. So, if you pre-check your tire pressures to what BK911 has mentioned here numerous times, you should be good for any environment. And the tool that Bensonoid pictured is about the easiest and least expensive way I know of to air up my tires. I keep one in the frunk at all times.
    Harrington, Australia
    Quote Originally Posted by MONK View Post
    That's what I use.
    Yep, yep, yep...... you and me both, Monk.... and for exactly the same reason
    HeliBars Handlebars
    Kenda Kanine rear.
    Yeah, along the lines of Jaybros amd others, I bought Lamont’s portable compressor which comes with a short, flexible hose, and you can preset a pressure. When FOBO tells me rear pressure is low, I can set the required pressure and screw on the flexible hose without even getting down on my knees (I sit on a low stool). It’s a bloody long way down to the floor for me ..... works a treat. But there is still the pain of getting that valve stem in just the right place
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2020
    N. Wilkesboro, NC
    On a side note, I was riding yesterday in 45* weather and my FOBO alarm went off. I keep my rear tire (still a Kenda ) @ 26#. FOBO was screaming at me that it got to 31.2#. Not sure why it was so upset although that did seem to be quite a bit of increase considering the ambient temp. I was less concerned with that than I would have been had the pressure dropped. According to FOBO, it's now back down to 26.5#. I love this FOBO app.
    An 'over-pressure alarm' like that will occur because too much pressure increase may be an indication that the tire is under-inflated for the ambient temps &/OR for the riding you're doing, and the pressure in your tire has risen too much from it's cold start/base setting.
    Depending on the system, these 'too much increase' alarms can be triggered by the actual pressure increase, or by the temperature increase that effectively causes the pressure increase in the first place - either serving to warn you that a rise like that might be due to a slow leak in the tire lowering the volume of air inside it sufficiently to be a risk (obviously not the case here, or it would now show a lower pressure!); or that the material/layers the tire is made of are at risk of 'de-construction' due to the increase in the tire's temperature.... albeit, you're probably not quite at that stage with just an 'almost 6 psi' increase from cold - but then again, if it increased that much fairly quickly, maybe so?!
    But you also need to consider what you were doing in the 20-30 minutes of riding immediately beforehand - if you were riding 'somewhat more spiritedly' than usual, that temp increase & the consequent increased risk to your tire might simply be due to that 'over-exuberance', and if you slow down & the alarm stops as the tire's pressure/temp returns to its normal range rather than showing a lower than normal pressure, then that's probably what it was, altho.... if you were here in Oz, you'd also need to consider if you were riding on a hotter road surface, or if that tire was more exposed to sunlight, but considering where you are/the ambient temps you report, there's probably not too much of a risk of either of those.... there again, it could be that your FOBO was responding to a temp/pressure increase that was largely in the valve stem itself, and not actually in the tire?!? As I've mentioned before, it does sometimes happen with these end of valve stem sensors - warnings or pressure changes being reported that other devices can't detect any reason for, and that (sometimes) seemingly 'self correct'....could've been due to quite a few things, and unless you can identify anything that was clearly different in the conditions or what you were doing/how you were riding at the time....
    That said, it's been a while, but I thought the FOBO system allowed you to set an upper & lower pressure or temp limit for the alarms, altho most systems do generally have default limits - often about 4psi....
    Feb 2019
    Portland, Oregon
    If you lose air when checking tires, as I did, Slime puts out a digital "no air loss" tire gauge. I have one and it works great.
    Sep 2020
    Platte City, MO
    Yeah, I was kind of thinking if you're losing a couple psi when checking the front tires, or rear tire, then either your gauge or your
    technique need some serious work. Those front tires aren't that small.
    But I also agree that the Slime digital gauges are first rate. I have three of them, and they all work a treat.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Default Try this...
    Here's the TireTek gauge I use for all three tires: https://www.amazon.com/dp/B01KAHVJ8Y..._tbo.Fb5X1TQ59
    TireTek has a very similar tool to attach to an air compressor. It uses a flip lever to lock onto the valve stem and allows you to both add and release air pressure without removing the tool:
    https://www.amazon.com/dp/B01AO1ZBLW..._sio.Fb0Y4BN4M
    Yes, I do usually have to kneel, front or rear. Generally I can see enough of the rear wheel to guesstimate where the valve is and find it easiest to reach when it is between 3 and 6 on the clock.
    I've had both of these tools for more than 3 years and no problems with either one.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Sebring, FL
    Nice, but guess what, Amazon says, 'not sure when or if this will be available'. That sucks.
