Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
  1. #26
    Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    OR; you could spend maybe $2 at a bicycle shop and get a 90° stem adapter and just leave it on all the time. Being made for bicycle tires they are rated for over 100psi. I've had one on our 2014 RT since the first week of owning it. Now a little over 7500 miles later--no problems whatever.
    Those who say " I can't" will always be right.
  2. #27
    Dec 2020
    Hartwell, Ga
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    How about using this. Minimal loss of air when removing. Screw off types lose more air. Heck, with 24" of extension you could sit in a chair and inflate. Good ol' Amazon.
    https://www.amazon.com/Show-Chrome-A...454698&sr=8-37
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
  4. #29
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Valkrocket View Post
    That's a great idea but you still have to move the bike around until you get the valve stem in the right place.
  5. #30
    A push-on chuck is a lot easier to get on the stem. Those kinds of chucks take a fair amount of finger strength to get secure on the stem.
  6. #31
    Nov 2013
    Oro Valley Arizona
    RYOBI makes a nice small compressor with a built in gauge and a clamp on to valve stem. This works perfectly for all tires up to 125#.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  7. #32
    Linden, CA
    Default Simple fix
    Quote Originally Posted by BikerBob View Post
    Is there any way to install another add on to make getting air in the rear tire easier?
    Next time you have to replace the rear tire, do this, before removing the rear tire
    mark the wheel on the other side of where the current valve is, now 180 degrees
    from that valve drill a new hole for a new valve that is closer to the edge but not where
    the new valve will hit anything now install a new metal valve or rubber valve, Yes you will
    have 2 valves in the wheel it's no big thing and it works very well.Just be sure
    you put it across from the old valve stem so it don't cause any balance problems.
  8. #33
    Feb 2019
    Portland, Oregon
    When I had car tires mounted on the front, I had them install longer valve stems. The made checking and adding air much easier. I don't know why BRP uses such short stems. Maybe they are two cents cheaper.
  9. #34
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    For those of you using the FOBO TPMS, what did you do to make their sending units fit on the short stems. I fond some short (1/2") extensions but was worried about stress to the rubber valves.
    thanks johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
  10. #35
    Active Member EdMat's Avatar
    Clinton, MS
    Quote Originally Posted by johnv50 View Post
    thanks johnv
    They seem to work fine on 2019 RT. Can't speak to the others but mine are pretty short. I do not use the supplied locks, can't see a need for them.
  11. #36
    Feb 2020
    N. Wilkesboro, NC
    thanks johnv
    They work just fine on my 2021 RT base. No issues, whatsoever.
  12. #37
    thanks johnv
    I think that for some obscure/indecipherable reason, BRP used shorter valve stems on some of the F3's outta the box (2017?? ) and those were a bit tough to fit the FOBO senders onto!
    No biggie tho, when you toss the Kendas & get some proper tires fitted, they'll probably hafta take the valve stem out anyway, so just get the tire fitter to use the next longer length valve stem then - no worries after that!
    That said, the valve stem extensions won't be seriously stressing anything - and if they do cause issues, it'll just highlight that you already had a problem that needed fixing anyway!
  13. #38
    Northern Kalifornia
    Quote Originally Posted by MONK View Post
    Work just fine on my 2014 RT also. No issues, whatsoever.
  14. #39
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    I just ordered a pair of these 90 degree stems from Amazon supplier. Anxious to install. It's a huge pain to even check the rear tire pressure!
  15. #40
    Mar 2020
    Martinez, CA
    90 degree brass stem was easy to install and makes Pressure Checks and adjustments sooo much easier. Best $$ spent in a while!
    I'll try to post a photo soon.
  16. #41
    Aug 2020
    California
    I used a clamp-on chuck for awhile. Getting it on was no problem, but taking it off was. Tended to get caught on the threads and released too much air in the process. Now I use a threaded chuck. I can reach the valve to screw it on for pretty much any wheel position. Losing air when unscrewing has not been an issue. My compressor has a psi setting, so it checks the pressure at the same time, adding air only if needed - two operations are no longer needed.
