Need help/vids on 2020 Panel removal?
Need help, I’m trying to fine a good video showing the panels being removed on a 2020 RTL.
Any specific panels you're planning on removing? The main ones (on each side) are easy once you've done it a time or two. My camcorder is the only thing that fits on my tripod but I'd be happy to charge up the batteries and shoot a quick vid removing the side panels, if you'd like. Have to (literally) blow the dust off the cam since I haven't even turned it on in about 3 years.
RT-S PE#0412
Yes Monk i would appreciate it IF you could video removing the left side panels to get the ECU.
I believe it's under the right side panel but I'll try to do that tomorrow. Couldn't get my camcorder to work so I'll have to figure out a way to mount my phone on my tripod.
I’m not sure Monk I’m getting a tune from Wick-it and from what I’m getting described in their pic it’s on the left. I guess It really doesn’t matter the panels are the same. Thx for your help.
I'll see if I can shoot a quick vid tomorrow of one side (both are the same) but that's NOT a 2020+ RT. That's a pic of the previous generation.
Ozzie Ozzie Ozzie
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Those vids are already easy to locate. I added the rear just to fill in the blanks since the rear is harder to locate and the OP stated, "Need help/vids on 2020 Panel removal?'.
