Results 1 to 14 of 14
    Nov 2020
    Pa.
    Default Need help/vids on 2020 Panel removal?
    Need help, I’m trying to fine a good video showing the panels being removed on a 2020 RTL.
    Feb 2020
    N. Wilkesboro, NC
    Any specific panels you're planning on removing? The main ones (on each side) are easy once you've done it a time or two. My camcorder is the only thing that fits on my tripod but I'd be happy to charge up the batteries and shoot a quick vid removing the side panels, if you'd like. Have to (literally) blow the dust off the cam since I haven't even turned it on in about 3 years.
    Apr 2016
    Albany NY
    Apr 2016
    Albany NY
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    Simple just google 2020 RT panel removal, looks like several videos available.
    https://www.spyderlovers.com/forums/...-Panel-removal
    or, the ad you can skip in 5 seconds
    Panel removal https://youtu.be/CI_dQry8SqQ
    Nov 2020
    Pa.
    Yes Monk i would appreciate it IF you could video removing the left side panels to get the ECU.
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by gunner View Post
    I believe it's under the right side panel but I'll try to do that tomorrow. Couldn't get my camcorder to work so I'll have to figure out a way to mount my phone on my tripod.
    Nov 2020
    Pa.
    I’m not sure Monk I’m getting a tune from Wick-it and from what I’m getting described in their pic it’s on the left. I guess It really doesn’t matter the panels are the same. Thx for your help.
    Quote Originally Posted by MONK View Post
    Last time I looked, the 'ECU type' box under the RIGHT side panels was the Control Unit for the Transmission (they do look very similar tho, but they should be clearly labelled!) However, that last look was almost a year ago now!
    All the F3's I've dealt with so far have had their Engine Control Unit (ie, the one you'll need to remove to send off to Wick-It et al for an upgrade) located under the LEFT side panels.
    Feb 2020
    N. Wilkesboro, NC
    I'll see if I can shoot a quick vid tomorrow of one side (both are the same) but that's NOT a 2020+ RT. That's a pic of the previous generation.
    Nov 2020
    Pa.
    Yes I recognized that also from the pic ( from Wick-it site ) that it was a different year. Ozzie Ozzie Ozzie said it should have a label identifying which it is. I’ll make a phone call to a dealer Mon. to fine out for sure.
    Sep 2020
    Middletown, NJ
    2020 RT base , Chalk White
    Harrington, Australia
    Quote Originally Posted by RayBJ View Post
    Yeah, but Gunner wants to remove his front panels to get to the ECU, Ray
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2020
    Middletown, NJ
    Those vids are already easy to locate. I added the rear just to fill in the blanks since the rear is harder to locate and the OP stated, "Need help/vids on 2020 Panel removal?'.
