Results 1 to 12 of 12
    Aug 2020
    California
    Default Any Compass' for Spyders that actually work?
    I would really like to add a compass to my ride. All the dash mounted bubble types I have tried are useless. Is there anything available that actually works?
    Nov 2020
    Mesa, AZ
    Feb 2017
    I use a compass app on my cell phone - when I care about which direction I'm headed. The one I use is called Digital Compass from Axiomatic, Inc. Found it at Google Play.
    Active Member EdMat's Avatar
    Apr 2019
    Clinton, MS
    I set my Garmin to display the compass in small window.
    Mar 2008
    Hesston, PA
    I also use marlinsclocks...Have been for years...Great products and service...larryd
    https://www.marlinsclocks.com/
    Jul 2014
    Mint Hill, NC
    Bulls-eye!
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Linden, CA
    Quote Originally Posted by wmjweber45 View Post
    YES
    Get one of my TackForm phone mounts for your spyder and use your iPhone with it set on compass
    that works great if you only want to see the compass.
    Or yo could use it for your GPS and that also has a compass visible
    Idaho
    I use a second older Android phone without cell connection and an app called GPSTest. It has several display modes. I have it show bearing, speed, and elevation. The app is free IIRC.
    2014 Copper RTS
    Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    None of the simple, floating ball compasses work on a Spyder's dash because of the electronic interference from the instruments. I wish it were otherwise. I have a simple basic Garmin that's too dim to read in bright light, even at the brightest setting (and besides, I want to view the map!).
    Idaho
    Quote Originally Posted by Fat Baxter View Post
    That's one of the advantages of using an old Android phone with GPS Test app. The display can be set to white numbers against a black background. Easy to see in daylight.
    2014 Copper RTS
    Apr 2019
    Florida Swamp
    I got a couple of compasses that I have had for many years. They don't install on the bike, truck, or whatever. They are fairly accurate, small, and when not in close contact with a lot of metal, don't need adjustment. One of them I carry in my shirt / jacket pocket. No batteries or electricity required. It is really a hiking compass, but works just as well on the the bike. Got another small liquid ball type that will pin to the sleeve of a jacket where it can be seen while riding. If you are doing land navigation off road or setting up a satellite antenna, you need real accuracy, but I never have really needed that kind of accuracy on the roads. You just need the general direction. You have to follow the road anyway, and with the exception of some roads out west, very few of them are straight for very long.
    2019 F3-S , Black & Silver
    aka: akspyderman ARtraveler's Avatar
    NW Arkansas
    The Garmin compass works for me also.
    Currently Owned: 2019 F3 Limited, 2020 F3 Limited, 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) 2011 RT A&C SE5 (magnesium) 2014 RTS-SE6 (yellow). 7 Spyders, 12 years, 175,500 miles
    2019 F3L , Phoenix Orange
