Results 1 to 11 of 11
    Nov 2020
    Las Vegas,NV
    Default And so it begins...
    The wife has been spending her Christmas money on Spyder parts and accessories, one of the first parts to arrive was the Can-Am Auxiliary light which goes on the front spoiler.
    Pretty easy install.
    1. Undo 2 Torx screws
    2. remove the honeycomb panel
    3. Unplug the cable from the panel
    4. Connect Cable to light
    5. Use the 4 Phillip head screws to fasten light in place.
    This light comes on when the Spyder is on and the engine is on just like the headlight.
    The light doesn't put out a ton of light in your path, but it does illuminate around the front of the Spyder which helps with traffic seeing you and also when riding in unfamiliar areas. You can see if there are dips and curbs easier.
    2020 RT , Chalk Metallic
    Danbury Connecticut
    You must be new. A very warm welcome to the group.
    You're about to enter a new dimension of modifying your Spyder.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Looks good.
    Sebring, FL
    Oh yes, many ways to personalize your Spyder. Enjoy!
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Farkling your Spyder is worse than being hooked on crack cocaine....
    ....or so I've heard.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Northern Kalifornia
    You can always join "Farkles Anonymous" if you have to.
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    I knew there was something I myself was supposed to do years ago!!! Too late for me. LOL
    Aug 2019
    southwest oHIo
    Everybody is tossing around the word "farkle" like they know what it means.
    Do you know that it's actually an acronym? (I do.)
    Can anyone else fill in the blanks?
    F ___________
    A ___________
    R ___________
    K ___________
    L ___________
    E ___________
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Clinton, MS
    Quote Originally Posted by Steve W. View Post
    F ___________ Fancy
    A ___________ Accessory
    R ___________ Really
    K ___________ Kool
    L ___________ Likely
    E ___________ Expensive
    Added answer above.....................
    Aug 2019
    southwest oHIo
    Absatively, posilutely CORRECT!!
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Feb 2020
    Ontario, Canada
    I put the Auxiliary LED light and the Signature lights on my RT, more for visibility ...others seeing me. I find the factory lights work really well
    2020 RT , Lamonster Brake Pedal Riser Petrol Metallic
