Results 1 to 25 of 32
    Aug 2019
    Stoughton, WI
    Default SpyderExtras F3 Front Grille Guard users - Thoughts? Opinions?
    Just inquiring to see if any F3 owner/members here have this grill guard installed? Yeah .. it's kinda pricey, but the heart wants what the heart wants Just curious about thoughts/opinions from any owners. Thx
    2022 RT Sea To Sky
    I do like the looks of it. I don't have one myself. Now it will really look like a Dodge truck.
    Aug 2019
    Stoughton, WI
    Ha .. Yup. Having a black F3S, I think it'll look bad azz
    2022 RT Sea To Sky
    Bossier LoUiSiAna
    Gill guard or push bars? Looks good is it beefy as looks?
    Aug 2019
    Stoughton, WI
    Deer Bashers ? Hopefully not too heavy. Might have to ramp up the preload to get some height back ...
    2022 RT Sea To Sky
    Feb 2019
    Portland, Oregon
    All I wanted was something that will lightly touch a concrete wheel stop in a parking lot before the plastic chin bar does. Rivco sells an attractive bumper at a high cost and it's not for F3 bikes. So I made my own out to aluminum bar and shapes, since I can't weld. If I could weld, it would have looked different and made of steel.
    Sep 2009
    La Valle, WI
    I dont think you can use your spyderpops bump skid with it since it has it's own built in skid plate. If you go that way I maybe interested in buying your bumpskid.
    2018 F3 Limited , Oxford Blue
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by JP58 View Post
    If you ae talking to me, I don't have a bumpskid. But the two 1/4 X 1" aluminum bars that the bumper is attached to will act as a skid.
    Sep 2009
    La Valle, WI
    I was referring to Troop. He lives near me and has the bumpskid on his F3
    Aug 2019
    Stoughton, WI
    PM sent. Sounds good JP.
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    Ordered
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    Arrived today and got it installed. I like it . I'll wait till another day and dial up the preload on the front shocks. This weighs 13#, so it won't hurt. I see some amber lights for it in the future too
    2022 RT Sea To Sky
    Sep 2009
    La Valle, WI
    Nice!
    May 2019
    Port St. Lucie, Florida
    I like it a lot! The You Tube video of an install looks easy. Is it?
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by carsong View Post
    Ha ... That's what I thought I drove mine up on tire ramps, which gave ample work room. I found a cardboard box the perfect height to hold the guard up. Weighing approx. 13#, and being a bit wide, it is very hard to hold upright without support. Plus, you don't want it hanging from a single (or double bolt). With the box centered underneath the guard, aligning bolts > bolt holes was MUCH easier. So, the answer is NO without a support, and YES with a support.
    2022 RT Sea To Sky
    Feb 2020
    N. Wilkesboro, NC
    Looks nice, troop. My only concern would be the (4) (2 on each side) bars that angle back towards the suspension. I can see hitting something easy enough to not damage the front of the bike but just hard enough to allow those (4) bars to contact the suspension. Might do a LOT of damage in an otherwise fairly minor collision.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by MONK View Post
    The photo is a bit misleading Monk. The end caps of the guards are 12" from the suspension. The guards crashing against the grill would prevent that. I think most damage would occur at the (4) lower mounting bolts. This guard actually has a touch more ground clearance than it did with my SpyderPops bumpskid installed. With the 2019 F3S having the ribs on the underside grill, the bumpskid actually sat 1/2" lower to the ground.
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    The grill came with mounts to add more lights
    2022 RT Sea To Sky
    Feb 2019
    Portland, Oregon
    I see a potential problem; where the oval tubing angles down and is welded to the supports that go under the bike, there is a sharp corner. When hitting a pothole or a sharp dip, that will dig in like a plow. I have already scraped the bottom front edge of my DIY bumper's channel, so I am going to replace it with round or half round material.
    Aug 2019
    Stoughton, WI
    We shall see. This will be approx. 1/2" higher than my Spyder Pops bump skid, as the underside ribs are not an issue to mounting. That did scrape a few times. Won't be riding here in WI for a couple months.
    2022 RT Sea To Sky
    Sep 2008
    TX
    I like the looks! Having just replaced the two "breakaway supports" on my '15 F3-S, after the bumpskid caught on a RR crossing, I would be wary of any structural function of the guard. There is no metal, other than the frame, anywhere close to the front end. Having a substantial weight cantelevered off the frame where the front suspension attaches may affect steering and handling, too. I'd rather replace the plastic pieces than the frame should I hit something hard.
    We've had/have 2 F3-S and 2 F3-T/L machines, with only one having the bumpskid. For me, the bumpskid is not going back on any of our F3 machines.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Jan 2021
    Colorado
    Arrived today and got it installed. I like it I'll wait 'til another day and dial up the preload on the front shocks. This weighs 13#, so it won't hurt. I see some amber lights for it in the future too
    I like it too.
    2012 RSS , Black&Green
    Nov 2020
    Ohio
    @Troop. I FEEL YA BUDDY.
    I was slinkin around online & randomly came across this back in Nov lastyear.
    debated. debated. debated some more. Then said the hell with it, bought it.
    Came in a nice giant double box, & quadruple wrapped. I’ve never had a safer padded shipment in MY LIFE.
    Used some DIY ramps to drive up & lift the front & jacks to stabilize.
    First time I ever lifted it, but the install went easy (2 out of 10). Instructions were better than expected,
    but were a little misleading for the F3-T.
    Is it Practical? ...No.
    Will it protect the front in a crash? ...Nope (at least not for anything faster than 10mph)
    Is it expensive? YES
    Does it lower your front clearance? YES
    Do I regret buying? ABSOLUTELY NOT. I LUV IT. Would do it all over again in a heartbeat
    Its for show, pure and simple. And it looks amazing.
    Can’t wait to throw on some different light options on it than the default ones,
    but haven’t decided on anything specific yet.
    2019 SpYder F3-T
    +Lamonster Mirror Locks AMEN! | +Lamonster FogLights | +MadStad Windsheild | +Dual A-Arm Running Lights
    +Spyclops LED Light | +SpyderExtras Grille | +TricLED Wide-VU Mirrors
    ...and what dreams may come
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Shadowrun View Post
    Heck Yeah Lights you say ?
    2022 RT Sea To Sky
    Member sparky1947's Avatar
    Feb 2023
    PA
    How many inches (overall length) does this guard add to the F3?? I have very limited space in my car and a half garage. Thank you.
