Results 1 to 5 of 5
    Very Active Member Martin Slovakia's Avatar
    Mar 2015
    Bratislava, Slovakia
    Default Step by Step PANEL REMOVAL for F3's
    Hi guys, here is the video how to remove the front panel from Spyder F3, F3s or F3T.
    More useful stuff can be found at MartinTheVlogger.com https://www.martinthevlogger.com/vlog-1<- click here
    May 2018
    millsboro,delaware
    Wow,I thought my RT was bad.
    : 2017 RTL ORBITAL BLUE
    Mar 2013
    My 2015 looked even worse - got to the point that it would over heat very easily. After pulling both radiators and spending 5 hours cleaning them I decided to come up with a way to reduce the junk that gets past the grill. Put a thin fiberglass filter (true blue brand) behind the grill to catch most of the crud before it gets to the radiators. Cheep and easy to replace. Did the same with my 2020 RT. Amazing how much it catches.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2015
    Quote Originally Posted by PW2013STL View Post
    That is a great tip. I will search for some options. Thanx for sharing
    Mar 2015
