Rear Tire Replacement
I have a 2011 RTS SE5 with over 30,000 miles and the dealership want to charge me 250.00 to change my rear tire, are they trying to rip me off or is that a good deal?
2012 RTS SE5
SpyderPops BumpSkid Guard
PowerSportsWraps Phoenix Bird
GloRyder Lights for Front Wheels with Remote
Lamonster IPS
PowerSportsWraps RT Dash Kit Woodgrain
Custom Dynamics Chrome License Plate Frame
Shortee Antenna
Knight Riderz Light Bar Blue
Front and Back Spyder Decal
Volt Meter
Digital Clock
Wolo Bad Boy Horn
Lamonster LED Headlights and Fog Lights
LED Tip Lights
LED Light Strips for Front Fenders
LED Light Strips for Left and Right Turn Signal
Third Brake Light for Rear
Is that with the tire or just service charge?
2012 RTS SE5
Lamonster IPS
Shortee Antenna
Volt Meter
Digital Clock
Wolo Bad Boy Horn
LED Tip Lights
There shop rate must be up there!! I would say that's 2 hr job, maybe 3! But unless you can do it yourself, what you going to do?
Am stuck between a rock and a hard place.
2012 RTS SE5
Lamonster IPS
Shortee Antenna
Volt Meter
Digital Clock
Wolo Bad Boy Horn
LED Tip Lights
If your handy with tools, and have a place to do it, you can find all kinds of you tube video's that will take you step by step on removal of the rear tire, then you could have a new tire put on your rim and save yourself a little service charge money! But if your not comfortable with wrenching then your right, rock and a hard place!! How about a friend??
Thanks for the good advice and wish me luck and blessings.
2012 RTS SE5
Lamonster IPS
Shortee Antenna
Volt Meter
Digital Clock
Wolo Bad Boy Horn
LED Tip Lights
If you R&R the wheel yourself, you can have a much superior car tire mounted at a regular auto/tire shop for less $$.
Was this at Mancuso? I recently priced a tire change at the gulf freeway one near the beltway on 45 and they wanted to charge me to 260 for tire change not including tire. At the LaMarque Mancuso they are charging me 160 to change the tire not including tire. My RT is there now. There is a member on here that was charging less but he couldn't get me into his shop until mid January. I'll use him next time and he sells/installs car tires on the Spyders. His info is below.
Also my direct email is jcthorne@thornolis.com and our web site at thornolis.com
SpyderLovers Ambassador
Tires
Good Luck on Your Mission. .....
ENJOY YOUR LIFE WITH A SPYDER
IMHO, 2 hours is excessive to change the rear tire. I'm not a mechanic but I'm 'handy" and I R&Red plus balanced in ~1 hour for the 1st time last month when switching to Q5 tires. I would think a professional shop would be more skilled and do it in similar or faster time. The hardest part is getting the spyder high enough to drop the wheel.
OK, last year I had all 3 tires "made new" (labor only) for $120 in the Phoenix area. Look for a privateer who has worked on Spyders. They are out there at reasonable prices.
Unless your going to be doing this a Lot of times its probably better to Pay $250 IF they allign the wheel properly because this can take a couple tries and each try is about 30 Minutes to adjust and test?
Sea Doo GTI-SE 90 Jet Ski!!
Thank you EDBLU for the information on Jcthorne, he took care of my Spyder did a good job and saved me lots of money. Had my tire replaced on 1-23-2021.
2012 RTS SE5
Lamonster IPS
Shortee Antenna
Volt Meter
Digital Clock
Wolo Bad Boy Horn
LED Tip Lights
see what happens??????????? didn't like the cost, so asked for advice here, and BINGO, got the reduced price answer or other options. GREAT FORUM!!!!!!!!!!!
I have the 2020 TR Ltd. I took off the wheel myself. Took it to my dealer. I had them order the new Kanine. Charged me $ 129 for tire and installed and balanced on the rim. Then I reinstalled the rim.
I had my tire, drove to the mechanic in Daytona (I live in St. Augustine but this guy comes highly recommended) and got tire changed. He said my brakes needed replacement so I agreed to do it. Total price $180. It took him less than an hour after I checked in. BTW he did not do all the stuff the videos show. He jacked up bike from back and took wheel off. That is bound to save a heck of a lot of time aince he removed none of the tupper ware.
2020 Petrol Blue Metallic RTL
There is no need to remove any plastic to remove a rear wheel. I have done 3 tires on my RT and never removed any plastic. Watch some you tube videos on how to do it and go for it.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
On an F3 or F3S you have to remove the rear fender.
I know you done tons of these, maybe hundreds, but I never had to remove the rear fender on my F3 or F3-S(Daytona) to remove my rear wheel. I didn't take the rear shock bolt out either. Just jack it up high enough after pulling the axle and it rolls right out.
